Need some new headlight bulbs
Hi what is the best headlight bulbs to get for my VW scirocco gt 2.0 and what bulbs fit please
My headlights seem not very bright
- Andy Rocc
Re: Need some new headlight bulbs
I have these in mine and im happy with them...
Thanks mate for your reply I will try some , I see they are H7 bulbs how many do I need 1 set of two or 2 sets of two
And are they all H7 bulbs ,thanks
- whiteDevil_170
Main beam and full beam are both h7. How many you need depends on if you are changing both. If just the main dipped beam then just one set of h7 bulbs.
Jack
Lets Roc
I switched to these:
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_847" onclick="window.open(this.href);return false;
Don't think they're any brighter, and the beam of light doesn't look that white... BUT when you stand outside the car and look at the headlamps, they look much whiter than most cars on the road.
Hi I'm going to change both so do I need 2sets of 2 h7 bulbs what are best to get I was thinking Phillips
Thanks mate so I need 2sets of 2 h7 bulbs to change all front lightswhiteDevil_170 wrote:Main beam and full beam are both h7. How many you need depends on if you are changing both. If just the main dipped beam then just one set of h7 bulbs.
- whiteDevil_170
Yes if you want to change both dipped and full beam then 2 sets.
I have osram night breaker plus as my full beam and they are excellent!
Jack
Lets Roc
Thanks mate I was thinking of them but read a lot of people saying bulbs blowing within a year , and I have had Phillips before and they have lasted for ages but cost more, thanks
I also need to change my headlight bulbs so I was thinking of replacing the dipped beam bulbs for the Philips ones and the full beam bulbs for the osram night breaker, will this be okay? I also need to change the bulbs for the sidelights and fog lights so can someone please reccomend me some, either led or a white light like the headlights, thanks.
Ring Ultima every time... That my personal preference based on testing I have carried out (I can't say any more as it was in relation to my day job, but what I will say is its the best £19 you will spend on bulbs, - H7 per pair via Ebay.. especially when the lamps are aimed properly) you can also get them for the fogs too which again makes a big difference.
Full Hex+Can VCDS if required - Nottingham / Derby area
