Hi everyone, hope you can help.
I have a 2010 2.0 tdi 140 and I'm having issues in the past couple of days. On the way home from work yesterday I noticed a juddering feeling when I was stopped at lights, it's hard to explain but I can just feel a shudder under foot every few seconds like it's spluttering or just struggling. The engine sounds different too, it's normally so smooth but it sounds rough. Then today when I got home from work and turned the engine off, the fan kept going for about 5 minutes as the engine was very hot. I can also smell what I think is oil. Does anyone have any idea what this could be? Thank you
Help please!
Re: Help please!
When the DPF does a regeneration, the car feels a little rougher and there is a sense of heat as to do the regen the exhaust temp is increased. If you switch off the car before the regen is complete the radiator fans run on for 5 mins to dissipate the heat.
Just give the car a good run to allow it to complete the DPF regen and all will be well☺
Ben0416
Re: Help please!
I'm scared to take it down the motorway incase it breaks down but do you think that will work? I always drive around town and people have told me before that caused issues because it's a diesel.
Re: Help please!
Yes, DPF doesn't like only town driving. Needs a good blast to allow the DPF the chance to Regen.
Just give it a blast, it will be fine.
- Roy_01
Re: Help please!
With the polar fis i can see in the mfd when a regeneration is performed. But you can also notice a shaky speedo needle driving on cruisecontrol. And fan turned on + oil smell is definitly a regen.
Ben0416
Re: Help please!
It seems to have worked, just took it down the motorway for 40 miles and all seems well for now. Thanks for your help, you've saved me getting ripped of at a garage tomorrow
Re: Help please!
You're welcome
- Irvysan
- I drive a: R-Line
- In: Ultra Violet
Re: Help please!
I was looking at the polar, worth the outlay?Roy_01 wrote:With the polar fis i can see in the mfd when a regeneration is performed. But you can also notice a shaky speedo needle driving on cruisecontrol. And fan turned on + oil smell is definitly a regen.
Sent from my LG-D855 using Tapatalk
