Boost Bar Sensor
TheRustySheriff
Options: Heated Leather seats, Sat-Nav, Bluetooth, Pan Roof, Rear Park Sensors
Boost Bar Sensor
Post by TheRustySheriff »
Playing round with my MFA i came across 'E-MFA' display which shows oil temp, water temp, speed, accurate engine revs, speed and boost pressure.
Thinking this was pretty cool, i drove around a bit and noticed the boost bar reading was showing 0.00 pressure.
I know there is no issue with the turbo so its got to be a sensor issue. Does anyone know if these are hard or expensive to replace?
Also, showing my naivety, what should running temps of water and oil be?
owen191
Re: Boost Bar Sensor
Post by owen191 »
Not sure about the sensor.... Water temp should be around 90, oil should be about 100-105 when properly hot.
