LED BULBS and RNS 510
m4pdy
Options: Heated leather, 12 way electric drivers seat, folding mirrors, DVD satnav, parking sensors, TPSM
Post by m4pdy »
hI all,
Love my rocco so far, just a couple of questions I want to ask, would like to know what LED bulbs if any can i use for the exterior bulbs fog, low beam (cree?) etc etc
Also i want to update my RNS 510 to 7 digit postcode entry how do i do this safely cant seem to find any info on this?
Thanks,
Paddy
Frostypaw
Options: REVO Stage 1, full ABT bodykit incl rims, black VW logos, otherwise debadged, pano sunroof, folding heated mirrors, dcc, lowered 25/30mm, dynaudio, satnav, full leather, extra woof
Re: LED BULBS and RNS 510
Post by Frostypaw »
Updating your RNS 510 I can help with - you need to find out it's version number. This can be found physcially on it if you're taking trim and bits out or via the 'hidden menu'. With the unit on hold down the setup button for a few seconds and a menu with some radio options and a 'test mode' entry or it may go straight to it
From that go to system info and it will tell you your hardware and software versions - you can then get the right downloads from http://www.my-gti.com/3868/volkswagen-r ... repository" onclick="window.open(this.href);return false; and burn and go!
If you've got an early version you may find the settings thing doesn't work - in that case install https://robpol86.com/guides/US-RNS-510-Video-In-Motion/" onclick="window.open(this.href);return false; video in motion and it enables it. Also early revisions did not have a HD partition for POIs so you may have to do a stepped upgrade so it does this. That will erase all the music/maps but i imagine you're upgrading your maps too
don't be fooled by the 'roc that i've got
m4pdy
Post by m4pdy »
Thanks for teh reply will check out the version in the morning and let you know... Yes i am updating the maps etc too. Where do i get the map updates from?
Thanks again for the reply.
AxG
Options: Full leather, HT Splitter, Dectane DRL's, AP coilovers, 19" Porsche 911 alloys, cc'd side strips and badges.
Post by AxG »
LED's should be CREE, I've had issues with cheaper ones.
I've just done the sidelights and number plate lights.
Buy cheap buy twice
robinalex
I drive a: GTS TSI
Options: Cruise control
Pano Roof
RNS315
Winter pack (heated seats / headlight washers)
Tyre Pressure Monitor
Electric seats
Parking Sensors
Bi-Xenon headlights with cornering lights
K&N filter
H&R 35mm
12.5mm Black anodised hubcentric spacers
Milltek Non-res catback
R-Tech Stage 1
Post by robinalex »
AxG, which Cree's would you recommend for the w5w DRL's?
Frostypaw
Post by Frostypaw »
I'm not sure posting links to download the maps would be cool as strictly that's rather naughty, but a google search with the unit type and a few more words should do you fine. They can be found on the torrent sites
casssh87
Options: 19" black Interlagos
Heated seats
Full leather
Post by casssh87 »
Im looking to update the firmware on the RNS510, iv pressed and held the setup up button to get the hidden menu but i only get the 2 radio options FM and AM. Is there another way? or am i doing something wrong?
AxG
Post by AxG »
http://pages.ebay.com/link/?nav=item.vi ... 1171258098" onclick="window.open(this.href);return false;
I bought these, my only issue was that the outside diameter was just flush with the housing of the right parking light. So it was a tight fit, but the rest were fine.
Maybe get a spare set in case
robinalex
I drive a: GTS TSI
Pano Roof
RNS315
Electric seats
Parking Sensors
K&N filter
H&R 35mm
R-Tech Stage 1
Post by robinalex »
Did they present any errors or have you got load resistors fitted?
AxG
Post by AxG »
Yeah I think the cree bulbs have a built in resistor.
No errors,
Had a cheaper set of LEDs in the numberplate which worked great until I swapped the sidelights then they both stopped working for no reason, even when I swapped for new versions of the same type !
But tried standard and cree and they both worked fine still
Frostypaw
Post by Frostypaw »
casssh87 wrote:Im looking to update the firmware on the RNS510, iv pressed and held the setup up button to get the hidden menu but i only get the 2 radio options FM and AM. Is there another way? or am i doing something wrong?
install video in motion and that should enable it
casssh87
Heated seats
Full leather
Post by casssh87 »
Thanks frostypaw! I will give that a go. :yes: :D
casssh87
Heated seats
Full leather
Post by casssh87 »
Worked! Thanks! :clap: :yes:
m4pdy
Post by m4pdy »
Thanks for the replies,
I tried holing the settings button to no avail. We, family and i are on holiday in Cornwall at the mo in the wife's car so will try doing the video in motion trick when i return. The link doesn't seem to work though?
Happy easter to you all.
Thanks again,
Paddy
casssh87
Heated seats
Full leather
Post by casssh87 »
m4pdy wrote:Thanks for the replies,
Thanks again,
Paddy
Just tried the link again, it seems to be ok. Also i had to hold down the setting button for an extra 15 or so seconds when the FM and AM appeared, and then it it opens another menu with version info.
Also does anyone know which firmware has the 7 digit postcode update? or is that under the map update?
Frostypaw
Post by Frostypaw »
casssh87 wrote: Also does anyone know which firmware has the 7 digit postcode update? or is that under the map update?
Yeah it's from the firmware not the map updates. The details should be on that my-gti link, but it's worth upgrading to the latest version you can so quickly becomes irrelevant
