DNX521DAB Help
Gibsonk
In: Pure White
DNX521DAB Help
Post by Gibsonk »
I have just purchased a 2015 Scirocco GT TDI.
The first thing I did with it is to dump the god awful RNS315 and pop in a dnx521dab.
I seem to be having a issue with the Bluetooth kit, everything I have read is that the phone should answer from the steering wheel, however it seems not to be the case, everything else works fine.
Integrated with OEM DAB and GPS Ariel, Climatronic and MFD
My question is there a updated CANBUS adapter for newer VW vehicles or is this a limitation with the older Kenwood unit.
Also does the newer dnx525dab display navigation info on the MFD I may consider swapping this for one or a RNS510 if I cant get the phone to answer via the wheel.
Thanks in advance
