Does anyone know how to remove the LED daytime running lights on an R and where the best place to get replacements is? Also, is anyone aware of any better, brighter versions compared to the stock LEDs?
Any advice appreciated!
Cheers,
Scirocco R - replacing LED Daytime Running Lights
- 3t3p
Re: Scirocco R - replacing LED Daytime Running Lights
I was wondeirng this too.
The DRLs don't quite look 'fresh' IMO
James321
You can access them by pulling out the black plastic grille underneath them, these just simply pull out and click back in. Once the grille is removed you will be able to see how they are mounted.
