Can somebody help me..
Im looking for some H&R springs for the Scirocco but i cannot seem to find them, they list all the Vehicles apart from the R.
Can someone supply me with a link?
Scirocco H&R Springs
- Huttchy
Re: Scirocco H&R Springs
Hello,
There has been quite a few posts about lowering springs on here! just use the search bar first, see if anyone has had a better performance gain with different springs.
otherwise here's two places I found them, alot of Rocco owners have mentioned AwesomeGTI so check them out (2nd link)
http://www.larkspeed.com/index.pl?p=HR290132E&a=i
http://www.awesomegti.com/car/vw/sciroc ... t-inkl-dcc
try that, they include
Just check your front axle weight (can be found on the black sticker on the inside of your door, just to be certain)
VW Scirocco Mk3 incl DCC & R 08/08 >
From 1021kg Front Axle Load
mond2k
- In: Pure White
just to be certain when you say From 1021kg this means anything greater than that weight?
- Huttchy
I believe so my friend! if anyone else thinks otherwise ??
