Sump Plug Type - TDI 170?
Vador
Options: 19" Luganos
Cruise Control
Winter Pack (Heated Seat Heaven)
Philips Bulb Upgrades
RLine Steering Wheel Badge
RLine Metal Pedals
VAG Scirocco boot liner
Avon ZZ5 Tyres
DRL Deactivated via VCDS
Post by Vador »
Can anybody tell me what the sump plug type is, I mean what tool I will need to remove it? :?
Going to do an interim oil service before my main service is due in May next year.
Oil is like black sludge as have covered 9k.
Cheers,
James.
Vador
Cruise Control
RLine Metal Pedals
Avon ZZ5 Tyres
Re: Sump Plug Type - TDI 170?
Post by Vador »
For the 33 people who had viewed the thread but couldn't answer.
Just changed the oil, it's a 19mm standard 6 sided bolt.
You need two sizes of torx bits to get the under-tray off to get at the sump.
Easy peasy Japanesy
