Hi
I was wondering if anyone could help me, for about four months now we have had a hesitation what appears like a minor misfire at low revs / light load. It is slowly getting worse but we have had a full service, new plugs fitted and its still the same. I have not started to check anything but was wondering if anyone else has experienced the same and if so what checks did you go through to rectify. Blockage in intake? O2 sensor? Coil pack etc.
The car is a 2009 2.O TSI, with a DSG gearbox and at cruising speed on main roads and motorways it runs perfectly, even under acceleration there is no issues its only when your idling along at low revs.
Hesitation / Misfire at Low Revs
Re: Hesitation / Misfire at Low Revs
Have a look at my (norco) posts. Hopefully there will be something in them that will be helpful. Mine is only really a problem until the engine reaches operating temp. Tried changing fuel but the problem is still there albeit less pronounced.
Many thanks, I will take a look
