dsg remap
- RavG99
Re: dsg remap
Nick rocco is. He doesn't like itrobbyg wrote:anybody running a APR DSG remap and if so any good??
- shshivji
- In: Opal Silver
Re: dsg remap
What's his reasons pal? Was thinking of having it done my self.....RavG99 wrote:Nick rocco is. He doesn't like itrobbyg wrote:anybody running a APR DSG remap and if so any good??
Shak
Re: dsg remap
Had it since it was released. Love it.
I'm running apr stage 2+ at the moment and it suits it very well.
The manual shifting is just waaay faster than stock.
Re: dsg remap
Cool I'm running APR stage1, so whats it like in D and S much diffrence??
Re: dsg remap
Well, D is now usable! It doesn't shift up to sixth gear as soon as you pull off. It stays in lower gears.robbyg wrote:Cool I'm running APR stage1, so whats it like in D and S much diffrence??
Before the flash I used mostly manual mode because of the useless D mode but now the new D mode behaves just as I would use the car in manual mode (cruising around town). So the new D is one of the best features for sure.
I don't use S mode at all. If I feel like giving it some, I just put it in manual.
Re: dsg remap
Can't let your comment about Drive being unusable stand without commenting. Drive is designed for general use and what most people want when they're not in press-on mode is economy so it goes into sixth as soon as it can. Well designed, good for what it is intended for and above all usable in your words for most people.
Can't help thinking the standard Sport setting does exactly what your Drive does after the remap.
Perhaps if you had tried Sport rather than just ignoring it you wouldn't have needed a remap. Then you would have had Drive as an option when you weren't in press-on mode. And still have manual for maximum-attack mode too.
Re: dsg remap
what a load of b...chelspeed wrote:Can't let your comment about Drive being unusable stand without commenting. Drive is designed for general use and what most people want when they're not in press-on mode is economy so it goes into sixth as soon as it can. Well designed, good for what it is intended for and above all usable in your words for most people.
A remapped Drive mode is definitely not the same as the stock sports mode. Couldn't be further from the truth.
I understand it is for general use, but the stock design drops the revs stupid low asap. Some say it's good for emissions, but it's def not helping with the milage.
The remapped D-mode has nothing to do with press-on mode. That is still done in manual mode. The remapped D is just a much smoother day-to-day experience overall.
Obviously I have tried and used the stock sports mode.
![Rolleyes :rolleyes:](./images/smilies/rolleyes.gif)
But that was even less usable running around town. The remapped sports mode made it actually a lot more civil. But this depends on the level of engine tuning as the different modes also takes into account the upgraded torque curves.
Perhaps you should try a mapped DSG before commenting about things you obviously don't have any experience about.
APR does trials for their remaps in UK as well I guess, might do for the DSG too. So go get it remapped, drive around for 30 days, flash it back to stock and THEN come back telling everyone here that the remapped D-mode is basically like the stock S-mode. Sorry, but before you do that, your comments about a remapped DSG are worth zero.
Re: dsg remap
Oh why don't you two love birds get a room!
Kiln I, how much longer does the APR map hold the gears in D mode, I always felt it shifted too soon in its rush to reach 6th gear when on a light throttle. Even in standard form it does seem to adapt well though, give it a little more load and it does hold on to the gears longer.
- lewihoga
Re: dsg remap
A somewhat narky response to someone just trying to help another out hachelspeed wrote:Can't let your comment about Drive being unusable stand without commenting. Drive is designed for general use and what most people want when they're not in press-on mode is economy so it goes into sixth as soon as it can. Well designed, good for what it is intended for and above all usable in your words for most people.
![shrug :shrug:](./images/smilies/shrug.gif)
Re: dsg remap
APRs PR team did a pretty decent job explaining the new d-mode:James321 wrote:Kiln I, how much longer does the APR map hold the gears in D mode, I always felt it shifted too soon in its rush to reach 6th gear when on a light throttle. Even in standard form it does seem to adapt well though, give it a little more load and it does hold on to the gears longer.
So basically it will stay in the current gear until the TCU thinks you will run out of decent amount of torque. So it's not RPM based but rather torque based and thus it depends on the level of engine tuning.APR about D-mode wrote:Drive mode’s performance and comfort is greatly improved based upon the current stage of engine performance. Gear change upshift and downshift points occur based on engine load and throttle position, rather than hard set points, and as such occur more smoothly and less abruptly. The driver may feel more connected to the vehicle as the gear changes occur more naturally. Under part throttle driving, the transmission will stay in the current gear until the appropriate moment necessary to shift, rather than jumping to higher gears too quickly.
I can only say that it feels perfect now. The new d-mode tends to change gear with normal load at 2100-2300rpm. I'm running stage 2+ at the moment but I had the DSG map when the car was stage 1 and it felt just as good but can't remember if the shifts occured earlier or later.
There have been some rare occations (driving at 50mph for long distances) where I would rather stay in 6th than 5th. In this case I just press + and the car stays in 6th even after it goes back to D-mode (pressing + in d-mode will jump to manual but jumps back after some time) and even if I slow down a bit etc. So it's not stupid.
I personally feel that 1900-2200rpm is a decent point to be at, running around town.
EDIT: I went for a drive to verify where the gear changes occur in D-mode. Edited my post accordingly.
Re: dsg remap
So basically my only small complaint about this DSG tune just got a fix!APR wrote:Version 1.5 is now available.
V1.5 fixes the common complaint in v1.4/1.41 that, in Drive Mode (not Sport Mode), the 5th to 6th gear upshift occurs at a higher than desirable RPM under light acceleration or constant speed conditions. The 5->6 shift points in a constant speed or ‘light to medium’ acceleration conditions have been reduced to as low as 82% of the v1.4 shift points, while the ‘medium to high’ acceleration 5->6 shift points have remained very similar to v1.4.
- 3t3p
Re: dsg remap
will it go into sixth at 30mph?
what is this obsession with straining poor engines.
you gotta be in the right gear for the task at hand and have acceleration if needed
Re: dsg remap
I have a dsg stage 2 remap, I prob prefer it over stock it's hangs on to gears a lot better and it's not just rushing to get into 6th gear every time possible plus there's no kickdown
Re: dsg remap
How much did you pay for stage 2 DSG remap and do you think APR is a better map then the Revo one?
Re: dsg remap
Im not sure how much I paid for stage 2 dsg remap cause I got it when revo had their offer on, Id wouldn't think there's much difference Between revo and aprStuWright13 wrote:How much did you pay for stage 2 DSG remap and do you think APR is a better map then the Revo one?
Re: dsg remap
Thanks for the reply mate but not for the battering last week.Arsenl4eva wrote:Im not sure how much I paid for stage 2 dsg remap cause I got it when revo had their offer on, Id wouldn't think there's much difference Between revo and aprStuWright13 wrote:How much did you pay for stage 2 DSG remap and do you think APR is a better map then the Revo one?
![Grumpy :grumpy:](./images/smilies/grumpy.gif)
Re: dsg remap
If you are thinking off getting the dsg remap its defo worth it in my opinion
