1 Check all the optional extras and Ipod cable
2 Full Spacesaver Sparewheel in boot
3 Check the condition of all the bodywork, wheels and interior, fog lights for stone chips
4 Marks on wheels from lashing ratchet strap from the transporter lorry
5 Look very carefully for any small dents or chips. Crouch low and look along the sides of the vehicle and all around for anything out of the ordinary. If the car is outside and it has been raining tell the dealer you will be inspecting the car as soon as it is dry as you wouldn't see anything small if wet.
6 Check panel allignment
7 Check the fit of the doors and boot
8 Have a good look at the seats and the fit of all the trim inside.
9 Check the transport blocks have been removed from the suspension springs
10 Manuals in holder and books have been stamped by the dealer
11 Make sure all other documents are in the vehicle wallet
12 Radio security code has been inputted and you have the number etc
13 Make sure there are no stray rags/cloths in the engine compartment.
14 Smoking Pack/Non smoking pack (which ever you ordered)
15 Check VIN numbers match between the car and documentation
16 Check the service regime
17 Check the bolt caps have been inserted in the holes on the wheels
18 Key adapter for locking wheel nuts (should be in the boot, with the spare wheel)
19 Two keys with remote locking functions, plus plastic key tag - with serial number, for ordering replacement key if necessary.
20 When you get the car home check the tyre pressures
21 Drive home with enormous smile on your face and enjoy
