High Rev Issue
Sebbristol
In: Salsa Red
Options: Sat Nav, Parking Sensors, Panoramic Roof
High Rev Issue
Post by Sebbristol »
I bought my first scirocco 3 weeks ago and for some reason the revs go up and down without actually me touching the gas pedal. It hapoens when I drive and when the car is parked up. I can hear the engine going louder and when I look at the rev counter that goes up and down. It's a 2.0 TSI GT.
Does anyone know what could be the issue ?
https://vimeo.com/102966151
Dubvrs
Options: XDS activated
Rain closure
Beep on unlock and lock
Panoramic roof
DAB
Rear parking sensors
Tan Vienna leather
Yeti tail pipes
Led number plate lights
Black VW badges
Golf GTI pedals
Re: High Rev Issue
Post by Dubvrs »
Dad had the same on his Fabia and it was diagnosed as a problem with the throttle pedal (same unit as in Scirocco) and has been fine since it was replaced.
If you can get your car to somebody with Vagcom you could look at the throttle position and see if it was moving on its own.
Sebbristol
In: Salsa Red
Re: High Rev Issue
Do you recon VW dealer will have this as I'm taking my car for diagnostic on Monday?
Dubvrs
Rain closure
Panoramic roof
DAB
Tan Vienna leather
Yeti tail pipes
Black VW badges
Golf GTI pedals
Re: High Rev Issue
Post by Dubvrs »
Dealer will have the equipment to look at the pedal position.
shshivji
In: Opal Silver
Options: panoramic roof and cruise control
Re: High Rev Issue
Post by shshivji »
Is it the same with the AC turned off?? Also how high and low are the revs going??
Shak
Sebbristol
In: Salsa Red
Re: High Rev Issue
Yeah I never use AC at the moment I just keep my windows opened. Do you recon that would be covered under warranty ?
Re: High Rev Issue
Car can also increase the idle revs if it detects a low battery voltage, in order to increase charge rate. Apart from the A/C, the Secondary Air Pump also can raise the revs when running. On a diesel, DPF Regen also raises the idle speed.
Sebbristol
In: Salsa Red
Re: High Rev Issue
Okay thanks well I'm taking it to VW Monday to have a diagnostic so hopefully they'll be able to see what's wrong!
