Window regulator
Window regulator
My passenger window had jammed so I decided to take it apart to see the cause. Turned out it was the window regulator cable that has worned out. And this window was not at use at all, only up and down during door opening and closure. If anybody is interested I can try to make a guide how to change window regulator for scirocco, didn't find it myself.
Re: Window regulator
There is à guide but for the vw eos which is the same if you search the net.
Looks like EOS has exactly same window construction, thanks for the tips!
