HOW LOW.......and find the Minion!
scirocco1984
Options: More than 300 characters!!!
Post by scirocco1984 »
Hi All hope your all good,
Going into my local multi storey and this is how close to catching my splitter is!!!!
Had to creep very very slowly.....
10 points to first person that spots the Minion??
Theres no such thing as "grey area" im just plain and simple "black & white"
Shaun1982
Re: HOW LOW.......and find the Minion!
Post by Shaun1982 »
Decked! Bottom of the screen for the minion?
Sent from my HTC One using Tapatalk
scirocco1984
Shaun1982 10 points to you ;)
fob163
In: Indium Grey
Post by fob163 »
in the back window!
Shaun1982
Post by Shaun1982 »
Yeeeeee. Where is your splitter from if you don't mind me asking please?
DannyR
Post by DannyR »
Lower grille white bits changes the look of that car. Looks brilliant.
Doubt it would look as good doing my viper green :(
scirocco1984
Shaun1982 wrote:Yeeeeee. Where is your splitter from if you don't mind me asking please?
Its off eBay item : 310782714450
Really good fit, comes with push clips and even uses 2 existing screws.
Drill 6mm hole and clip it on. If you dont like it then take it off and holes wont be seen because under lip.
Come ready to fit in a glossy like plastic finish
scirocco1984
DannyR wrote:Lower grille white bits changes the look of that car. Looks brilliant.
I think it would look great, any vibrant colour is a must. I rekon your green would look wicked tbh. But if i had grey or black scirocco i wouldnt bother.
scirocco1984
fob163 wrote:in the back window!
Yes Fob163 i also have in back window so i think 10 points to you also ;)
Shaun1982
Post by Shaun1982 »
Cheers mate I'll check that out
