Fitting new center caps?
- 3t3p
Hi
My chrome center caps were fine until I used turtle wax wheel cleaner which said it was safe on chrome.
Its not awful but it has started the corrosion process.
Who knows:
a) what replacements I need (18'' interlagos)
b) where to get genuine items from
c) how to fit them/take off old ones is the hard part I suspect
Thanks,
Who knows:
Thanks,
Re: Fitting new center caps?
They aren't chrome, they are made of plastic.
1. 65mm
2. If in the UK, your local TPS or local VW dealer.
3. They just pop out. Either drill a hole in the centre or use a thin piece of flat plastic on the edge to prise off.
1. 65mm
- 3t3p
thanks for that
I realise they are chrome plated plastic
I bought a set from eBay, genuine VW ones, £10 inc delivery
If the wheels off you just pop them loose from behind with something soft and round (but less than 65mm) usually the wooden handle of a hammer. No need to damage them or prise them out.
Dont forget the ''offical vw position'' for the centre cap is to have the ''w pointing towards the tyre vale. I kid you not.
I always park so mine are the right way up.VW Steve wrote:Dont forget the ''offical vw position'' for the centre cap is to have the ''w pointing towards the tyre vale. I kid you not.
Dealer changed mine under warranty, no quibbles
- 3t3p
ok taking the wheel off is not an option for me.
can they be removed externally without damaging the surround?
maybe a suction cup would work?
Like I said on my previous post, they can be prised off with a thin plastic blade. Tjete is a small cut out in the cap to allow you to do this. You could use a screwdriver but there is a risk of damaging the wheel.3t3p wrote:ok taking the wheel off is not an option for me.
Another.option is to drill the centre of the cap a pull off.
- 3t3p
ok thanks i'll take a closer look
Just replaced my centre caps as they'd gone all milky looking. If you're not bothered about the old ones then just screw in a self tapping bolt or screw and pull them out with pliers. It's really simple and takes seconds.
- 3t3p
cheers for the tip.
And new ones just press-fit in I presume?
Yes3t3p wrote:cheers for the tip.
