I'm going to buy 3sdm 0.01 19 ", but I'm pretty green at this and really do not know which of the width / offset should I choose not to rub the wheel arches during a normal drive and from falling in potholes ( polish poor roads...) . My car is on eibach pro kit ( -30 f, -25 r ). I thought about 8.5x19 ET32/42 on 235/35/19 or 9.5x19 ET40 on 245/35/19. What you advice me ?
Either 8.5 et 32 all around, or 9.5 all around with 5 mm spacer on the front, as ET 40 rubs on the abs-wire if you lower it a bit more. Either way, use 235/35 tyres
