Engine coolant
lokyt
Options: 18" Interlagos, Vienna Black Leather, Cruise Control, Rear Parking Sensors, Winter Pack, Dynaudio Pack, Badge Deletion, Electric Mirrors, Stainless Steel Sills, Alloy Pedals, LEDs
Engine coolant
Post by lokyt »
Just checked my oil etc and noticed that the engine coolant is at the minimum level. I have been informed you can used distilled water to top it up to midway between min and max levels.
Question is does anyone/can you use the distiller water from a dehumidifier? What do you guys recommend?
Lokyt
skippy
Moderator
Re: Engine coolant
Post by skippy »
I did use a little distilled water when mine had a slight leak (dealer recommended) to top up. So long as it is just small quantities there should be no problem. Ideally should be the G12/13 coolant to bring the level back.
Probably could use the water from a dehumidifier, again small quantities only.
yellowplum
Re: Engine coolant
Post by yellowplum »
How easy is it to get distilled water, no one round here stocks it and they all offer deionised water (which they don't understand is not the same as distilled).
skydemon
Options: R line pedals :-)
Re: Engine coolant
Post by skydemon »
Just use rainwater dude. Distilled but not pure but perfectly ok ;-)
AaronMc
Options: Black Pack inc 19" Luganos, Piano Black Dash Inserts, Heated Vienna Leather, Dynaudio, Scirocco R Pedals, Parking Sensors, Needle Sweep Activated, Black VW Badges, Debadged, H&R 35mm.
Re: Engine coolant
Post by AaronMc »
Deironised water is available from all car factors.
My tesco also stock it!
yellowplum
Re: Engine coolant
Deionised isn't Distilled water
