So what is everyones opinions on the best combination for a Stage 1 ECU remap and DSG software remap in the UK? Car is stock and Im based in Kent, so Ideally I dont to have to travel big distance to get it done. Revo seems most established in this field?
AMD offer this, but don't associate it with Revo?
Many thanks
Best Stage 1 and DSG remap?
Re: Best Stage 1 and DSG remap?
I have Revo stage 2, works brilliant
Sadly not found anywhere near by that can do DSG mapping
hi mate
i also live in kent. I run stage 2+ AMD custom map with their DSG map as well. never once had a problem, great customer support at AMD always.
Revo and apr = best seller in my country, indonesia.
- RavG99
Does anyone else rate amd as im consider who to get my stage one done from as the gains are all the same roughly so price and service and quality is factor now
Sent from my GT-I9505 using Tapatalk
As yours is DSG too, I'd get it done by AMD as you should hopefully be able to get a package to map both parts.
I went with REVO whom currently don't over DSG maps
RavG99 wrote:Does anyone else rate amd as im consider who to get my stage one done from as the gains are all the same roughly so price and service and quality is factor now
They've never done me wrong mate. they gave me a deal to do both the remap and the DSG map, got some good results.
I got this from More BHP when I enquired.
Stage 1 Engine ECU Upgrade £199 -Dyno runs £50 (only available at HQ Crewe) -Stage 1 DSG ECU Upgrade £149 Total: £398 For the DSG box we can increase the standard torque limit from 350nm to 500nm, decrease the shift times by 15%, increase the max shift rpm limit from 6800rpm to 7200rpm (can be adjusted for D/S/M modes), increase the launch limit to 4,100rpm. I would expect performance to be around 300-310bhp / 400-420nm depending on the fuel you run, Shell V-Power recommended.
