How do Auto Lights work?
- Minnu
So, i have auto lights, but if i am sat in the car with the engine running, at night, i can't switch off the lights! whats that about?!
I tried to just switch my lights to the off position, so i dont disturb neigbours, but the lights stay on....is this normal?
Thank you
Thank you
Rising Blue Scirocco Sat Nav/Heated Leathers/Park Sensors/Pan Roof/19" Lugano Wheels
- Kev
- Administrator
Re: How do Auto Lights work?
Yep.
Try turning it one click to the right. It'll turn off the main lights and just leave the little side lights next to the indicators and the rears on.
The lights that stay on are your Daytime Running Lights.
A legal requirement from 2010 on..
- sbull92
I have noticed if you have the lights in the on position (far right turned) then it will stop the welcome lights coming on if thats what you mean by disturbing the neighbours. You can prob do it in the menu's for the welcome lights, I just find it a lot easier than changing settings all the time
2009 Rocco GT 2.0 TDI 140BHP Candy White
- Minnu
just to clarify, one click to the right from where? lol from 0 (off)? so on auto? i've tried it on "0" "auto" and the main light (whatever the symbol is. On the side lights, it switched off....well, to side lights only.
also, the daytime running lights are the little lights below the main lights. either they're uber bright, or theres a problem.
Also, to add, there is some sort of electrical box with wires coming out of it in my compartment to the right of the steering wheel. the elec box is loose, and moves around....any ideas? related to the lights maybe?
Here's a reply by UKLee to a post of mine regarding lights.
Hope this helps.
uklee wrote:Hi Brocky
I cant speak for the halogen equipped cars , but on mine (with Bi-Xenons) this is how it works.
I understand that lots of folk refer to their sidelights as DRL's - especially when they've fitted aftermarket sidelights - I have dectanes (here's a pic to avoid any confusion)
The DRL can be switched on or off via the lights & convenience menu in the MFD . This is standard on Bi-Xenon cars and doesn't require VCDS to enable it.
With the light switch set to '0' (Day or Night), and the DRL's enabled , then only the DRL's light up , if the DRL's are disabled in the MFD menu , then the DRL's do not light up (nor do any other lamps illuminate)
With the light switch set to 'Auto' , and the DRL's enabled , then the DRL's light up as soon as you turn the ignition on. When night time comes , the headlight dipped beam and the sidelights come on. The DRL's go off
With the light switch set to 'Auto' , and the DRL's disabled , then the DRL's do not light up at all. When night time comes , the headlight dipped beam and the sidelights come on.
With the light switch set to 'sidelights =oo= ' (Day or Night), only the side lights illuminate - it doesnt matter if the DRL's are enabled in the menu or not - they dont light up.
With the light switch set to 'headlights =D ' (Day or Night),the headlight dipped beam and the sidelights come on - it doesnt matter if the DRL's are enabled in the menu or not - they dont light up
Hope this helps.
- Minnu
interesting, thanks for that!
i dont think i have Bi-Xenon lights....
i'll run some tests later to check
Thakns for that, very helpful!
No problem.
I think the lights should work the same, whether they're Xenon, or not.
In your case, the side-lights (lower bumper lights) are the ones that are staying on when the switch is in the 'OFF' position. They are always on, when the ignition is on.
- Kev
- Administrator
One click right from '12 o'clock'.Minnu wrote:just to clarify, one click to the right from where? lol from 0 (off)? so on auto? i've tried it on "0" "auto" and the main light (whatever the symbol is. On the side lights, it switched off....well, to side lights only.
If you have a car with halogen headlights the "Auto" function is redundant as the dipped beams are always on in lieu of DRLs.
Off - Sidelights and Dipped Beams On
Auto - Sidelights and Dipped Beams On
Sidelights - Sidelights On
On - Sidelights and Dipped Beams On
Only way to get Auto function to work is to connect VCDS and disable dipped beams as DRLs.
Xenon cars are different as they have dedicated DRLs either in the headlight or in the case of the R an LED strip below the headlight.
The small lights next to indicators are sidelights and not running lights or DRLs
So both dipped and sidelights are always on, even when the switch is in the '0' position, on non-xenon cars??
YesBrocky wrote:So both dipped and sidelights are always on, even when the switch is in the '0' position, on non-xenon cars??
I have a brain wave - why don't we put all the questions on lights into one post and make it a sticky as it must easily be the most asked question?!
<<<< He who laughs last, thinks slowest. >>>>
Urgh. Don't like the idea of that, tbh.Cuprabob wrote:YesBrocky wrote:So both dipped and sidelights are always on, even when the switch is in the '0' position, on non-xenon cars??
Glad I chose to stump up the extra cash for Xenon now!
No - they are just headlights stuck in the 'on' position in an attempt to mimic a DRL function (see Roccopedia) - there is no requirement to have this function on a Scirocco as the legal requirement for DRL lighting is only on cars designed and Type Approved after Feb 2010.AaronMc wrote:The lights that stay on are your Daytime Running Lights.
This 'hack' can be turned off with VCDS ina minute or two and returns the lights to normal auto functioning.
- Minnu
I knew it!!!
Thanks guys, I thought they were broken!
- whiteDevil_170
I agree. This topic is the most asked question on the forum. Other than bluetooth related questions.rm0rgan wrote:I have a brain wave - why don't we put all the questions on lights into one post and make it a sticky as it must easily be the most asked question?!
Jack
Lets Roc
- grantm1986
Sorry I'm new to the rocco club but I'm gathering that vcds is a vw diagnostics tool ? And to have the DRL's turned off you would be aswell taking it to who ? The dealer or would a small mechanics be able to do this ?
I have had my car almost 6 years and I am still confused on this issue.
I always gave mine in auto but every time I get it back from servicing VW turn button left to "11 o clock".
Too complicated for me.
Hi guys,
How come my side lights are always on? No matter what dial i use they will be on regardless of what time of day it is. I recently purchased LED sidelights and wanted my drls off but keep sidelight on. I have been told that i cant use the sidelight only function to drive round (main drls will be off and just sidelight LED will be on). Is it illegal to use side lights only? as they are constantly on regardless and i dont want the drls on during the day, ofcourse when its dark i will put it back to auto so they come on.
Regards,
Adam
Regards,
Adam
