Scratched Windscreen
markjp
In: Ultra Violet
Options: Folding Mirrors, Cruise, Dynaudio, Electric 12 Way Seats, Smoking Pack, 90% Rear Tint, Gloss Back Door Mirrors
Post by markjp »
I've noticed a few scratches on my windscreen shortly after scraping my windscreen with an ice scraper.
Is it possible to scratch the windscreen with an ice scraper?
Is it possible to polish these scratches out? If so what product would you recommend.
Jay Scott
In: Pewter Grey
Options: Leather Interior, Winter Pack
Re: Scratched Windscreen
Post by Jay Scott »
I've looked into this very briefly in the past and from what I was able to gather it is extremely time consuming to 'correct' glass. It might be possible to remove light scratches however if there is any significance to the defect it's unlikely to polish out as glass is so hard. You would need to use a machine polisher with a Cerium Oxide polish such as CarPro Ceri-Glass and the Rayon Glass Polishing Pads. I believe the technique is similar to correcting scratches in paintwork but it takes a hell of a lot longer.
markjp
In: Ultra Violet
Post by markjp »
Jay Scott wrote:I've looked into this very briefly in the past and from what I was able to gather it is extremely time consuming to 'correct' glass. It might be possible to remove light scratches however if there is any significance to the defect it's unlikely to polish out as glass is so hard. You would need to use a machine polisher with a Cerium Oxide polish such as CarPro Ceri-Glass and the Rayon Glass Polishing Pads. I believe the technique is similar to correcting scratches in paintwork but it takes a hell of a lot longer.
How come it's so easy to scratch the glass with a plastic scraper, but extremely difficult to polish out?
markjp
In: Ultra Violet
Post by markjp »
This is the ice scraper I used.
http://www.halfords.com/webapp/wcs/stor ... yId_255238
I used the side that is made from clear plastic, not the rubber bit.
If you have one I wouldn't recommend using it.
markjp
In: Ultra Violet
Post by markjp »
Anyone recommend an Ice scraper that is safe to use?
Or is it best to stick to using hot water or de-icer?
Kev
Administrator
Post by Kev »
The scratches tend to come from using a back and forth motion. You can trap small specks of grit under the blade and then you drag them back. You should just scrape in one direction.
I tend to use de-icer and warm water though. There are people who say de-icer corrodes the rubber seals but I've never noticed it in years of using it on past cars. Once you set off it's likely to stream off the car anyway.
markjp
In: Ultra Violet
Post by markjp »
Anybody tried kits like this with any success?
Brocky
Post by Brocky »
I would advise looking on Detailing World, before buying products or attempting windscreen polishing, Mark.
I've never tried it myself, but I'd imagine that there is very little margin for error when it comes to your pride & joy's windscreen, tbh.
Dave_Plumber
Options: Black Leather, Parking Sensors, 19" Luganos, Black Headliner.
Post by Dave_Plumber »
I have some minor marks from road dirt and the wiper blades I would like to get rid of. Got a porter cable 7424 was wondering if this is possible?
Brocky
Post by Brocky »
As I said in my earlier post, Dave, check out Detailing World. There are many folks there with huge experience in polishing etc. :yes:
lloydie63
Post by lloydie63 »
Hi, I had several light scratches on my rear window caused by grit on my bike rack. it was driving me nuts so I bought SCRATCH DOCTOR GLASS REPAIR KIT. there is a youtube video " onclick="window.open(this.href);return false; showing how to use this. So I followed the instructions to the letter and I'm happy to say the scratches have gone but it is very time consuming, I did mine over two days, an hour a each day, reason was I was getting bored and started to leave the polisher on the glass longer than recommended (glass is in danger of cracking if it gets too hot) but in the end I'm happy with the results.
Vador
Options: 19" Luganos
Cruise Control
Winter Pack (Heated Seat Heaven)
Philips Bulb Upgrades
RLine Steering Wheel Badge
RLine Metal Pedals
VAG Scirocco boot liner
Avon ZZ5 Tyres
DRL Deactivated via VCDS
Post by Vador »
markjp wrote:This is the ice scraper I used.
Shi*e, I have one of those! it's just become bin fodder.
