Heater question ???
Bluester
Heater question ???
Post by Bluester »
Hi all, this is the first time ive been driving in colder weather in my 1.4 160 ,with the heater set at 22 it gets lovely and hot but if i go round a corner it seems to go cold for a bit then back to hot, has anyone else had this or am i just trippin out :?
slimjimmy23
Re: Heater question ???
Post by slimjimmy23 »
Mine seemed to do this. Then I noticed that the passenger vents were blowing cold air even when set above 20.
So when I turned, the cold air came into the driver area.
The "temperature flap motor" was a fault.
I got mine fixed under warranty. Part should have been £118.00 and labour £86.00.
Hope that helps.
Gray170TDI
Options: Used to have one
Post by Gray170TDI »
I've noticed this too and it was the same on my MK5 Golf GTI. It's not a fault with yours, it seems all VW's on this platform do it
