Rattle on 170 at low revs
I have had a rattle/low rumble between 1200 and 1400 rpm in all gears and at idle for quite a bit now and decided to have a proper look today. Initially my first thought was the something with the engine so i took all covers off and had a wiggle about, i started it up and had a friend hold the revs at 1200 and move up and down between 12 and 1400rpm i noticed almost straight away it was the air intake to the airbox vibrating quite loudly. Turns out the mounting/gromit for the air box needed nipping up a bit and a little bit of foam padding underneath and above the intake scoop/difusser where it meets the front sill has sorted it out quite nicely. Hope this helps any one else on there rattle hunts ![Smile :)](./images/smilies/smile.gif)
Re: Rattle on 170 at low revs
Just another quick one, the above helped but it still rattled a little so ive now felt taped the rim on the cover of the air intake scoop and round the inner edge of the intake u bend where it enters the air box as this wasnt a very good fit. Its all tight now (with a little flex still) and know rattles/rumbles. ![Smile :)](./images/smilies/smile.gif)
I've noticed mine doing this on and off. Thanks for the post, ill have to have a look and try get it fixed ![Big Grin :D](./images/smilies/biggrin.gif)
