Hey guys,
Could you help me with size of the rims? I have 18", 8,5 width and ET 35. Will they fit my Rocco?
Thanks a lot,
Michael.
Rims size issue :)
majkilipa89
Re: Rims size issue :)
As long as the PCD is 5x112 and Centre Bore is 57.1mm, they should fit although the outer clearance will be reduced by 12mm compared to the standard 8J ET41 wheel. The inner clearance will be the same as the standard wheel.
majkilipa89
Thanks a lot mate!!
