VW Service
langum25
In: Pewter Grey
VW Service
Post by langum25 »
When I switch on the ignition the service indicator is at approximately 3500miles but the indicator above with the little clock, which I think is the days till the next service indicates 20.
Which indication should I go by?
I am unsure what service plan it is on. It was serviced at about 7000 miles and its currently sitting on about 25000.
Thanks.
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: VW Service
Post by dimexi »
You go by the lowest - so 20 days will be when your service is due. It is likely to be on a time/distance service from what you say. So I presume you haven't reached the mile threshold, but the time one has been reached.
langum25
In: Pewter Grey
Re: VW Service
Post by langum25 »
thank you! :D
