Glow plug flashing and engine warning take to garage
daygo1966
In: Indium Grey
Post by daygo1966 »
Hi i have now had above problem twice . Turning engine off and back off clears problem but under load it reappears
The code showing on 00665 over pressure EGR unit
I do not want to start changing parts until i am sure what is problem
Any help would be great thanks
semtex
Re: Glow plug flashing and engine warning take to garage
Post by semtex »
http://wiki.ross-tech.com/wiki/index.ph ... 299/000665" onclick="window.open(this.href);return false;
read last line,not sure if it aplies for your car
my ride http://www.sciroccocentral.co.uk/forum/ ... =13&t=8440" onclick="window.open(this.href);return false;
daygo1966
In: Indium Grey
Post by daygo1966 »
Thanks i will check this out
mysciroccoRocks
Options: All of them!
Mirrors pedals and seats
Post by mysciroccoRocks »
Did you sort it out ? 16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
My wifes car is showing the same code... and my pal has replaced 3 egr valves due to short stop start journeys our muchan-ic thinks...! Friday car I reck... :faint:
