Headlight Washers
- I drive a: GTS TSI
Headlight Washers
My car seems to have just started washing the headlights every time I spray the windscreen rather than every fifth time I think it was doing before. Anyone got any ideas why this might be?
Re: Headlight Washers
It's a setting that can be changed using Vagcom /VCDS.
Don't know why it would change though.
Remember it's every 5th time after the 1st time and not simply every 5th time, if you know what I mean.
I looked in Vagcom on my car & mine had a fault,headlamp washer relay fault, I don't even think mine washer at all ?
2009 2.0gt tdi 140bhp
2003 Suzuki Gsxr 1000 Rizla green/yellow (My baby) !
A little tip you can try. If you quickly pull the washer twice it will only do the windscreen.
Well in all my years, I never knew that! Thanks for the tip.. will help keeping the front end clean anywaymartdy wrote:A little tip you can try. If you quickly pull the washer twice it will only do the windscreen.
Golf 7R
Gone: Scirocco R
VCDS available
Gone: Scirocco R
VCDS available
Is there a sngle person that actually like having these washers?
Like's a bit far but I don't dislike themMark V wrote:Is there a sngle person that actually like having these washers?
- chr15
Just pull the fuse out
Which fuse is it, just so I know if that's what's wrong with mine ?
I vcds mine to spray on the 10th
- chr15
Can't remember but it's in the bookSkollers wrote:Which fuse is it, just so I know if that's what's wrong with mine ?
Evening, had a look today for a suspected blown fuse on my headlight washers & yes no;36 fuse had blown, haven't tried em yet as my car was clean lol I'm sure I will find out if they work later in the week !
I disabled mine within a month of owning it!
http://www.qualityreflects.co.uk" onclick="window.open(this.href);return false;
Regular work updates here:
http://s712.photobucket.com/albums/ww12 ... yReflects/" onclick="window.open(this.href);return false;
http://www.facebook.com/pages/Quality-R ... 4070809482" onclick="window.open(this.href);return false;
Twitter: @qulityreflects
