Disabling the annoying Stop/Start
JJ_ROCGT
Options: Cruise Control, Xenon headlights, factory de-badge, Metal pedal kit.
Post by JJ_ROCGT »
It's probably been covered but after 20 minutes searching i've given up!
Does anyone know how to disable the stop/start feature?
JJ_ROCGT
Re: Disabling the annoying Stop/Start
Post by JJ_ROCGT »
Forgot to mention i can obviously turn it off on the button on the dash but it just resets next time i drive it, so i'm looking to permanently turn this off.
trix
Ordered 23rd June 09
Build week 41
Handover 17th Oct 09
Missing RW1
Post by trix »
JJ_ROCGT wrote:Forgot to mention i can obviously turn it off on the button on the dash but it just resets next time i drive it, so i'm looking to permanently turn this off.
doesn't look like it http://www.sciroccocentral.co.uk/forum/ ... off#p64799" onclick="window.open(this.href);return false;
as that feature is part of the reason it has got the tax banding etc I really don't think they would let you turn it off completely.
(not sure what terms you were searching for?)
JJ_ROCGT
Post by JJ_ROCGT »
Cheers Trix
RW1
Legend
Hi from Sunny Stopfordia
Post by RW1 »
Stop-Start is a spider's web in the wiring. It would appear, the focus is the Engine ECU Controller - 01.
An VCDS Autoscan of a none stop-start Engine Controller 01 v a similar normal Engine Controller codings may show up the bit that codes it. It may be around bit 9 in the controller coding that disables it or enables it.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
scott.taylor
In: Indium Grey
Post by scott.taylor »
It can be disabled with VCDS. I almost done mine, but then decided to leave it.
MARCO_90
I drive a: 1.4 TSI 122/125
Post by MARCO_90 »
you managed to turn it off? how did you do?
VW Scirocco R-Line 1.4 TSI 122cv Candy White
http://scirocco.forumfree.it/" onclick="window.open(this.href);return false;
