I'm trying to get rid of one that sounds like it's coming from the dash somewhere, possibly above centre vents.
More of a buzzing noise, when it comes, pressing the dash down above the vents stops it..
So far I have removed the centre vents, dissembled them and used flexible butyl cord (door seal cord from my old Cupra), sticky stuff, great for stopping any plastic creaking. No joy though..
Next I removed the skuttle panel and packed the bracket that holds the ecu unit under the screen, the foam strip was already fitted between the glass and wiper mounting bracket.
Also fitted the foam pads below the skuttle panel at the strut mounts and at the bonnet stay.
So far none of these have worked, is there any where else to try??
I'm thinking a loose wire under the dash or a loose metal clip somewhere dash area?
Although I do know how these sounds can be deceptive and tricky to locate.. I did own a seat...lol
Need some help on this one, thanks for reading the epic long post...
