Aux & media help needed
Whenever I plug my iPhone in either through the cable that plugs in under the arm rest , or the aux cable , the sound is horrible & crackly , but via radio or CD its crystal clear , there has been one time it's played clear through the cable , do you think it is a fault with the cable it's self or is there a wrong setting that's on ? Any one else had this problem ? Any help would be amazing , thanks .
- RisingRoc
Re: Aux & media help needed
Is your iPhone in a case? Remove the case to make sure the cable is fully engaged and see how it works.
- whiteDevil_170
What unit do you have rns etc? I know that on my rns315 when you go in to sound settings you can adjust the sound output for mdi and Bluetooth audio. I have mine set to low. But if its set to high and you turn it up half way that could cause poor sound quality and make it crackle.. just a thought.
Jack
Lets Roc
Lets Roc
iPhones not in a case no
I'm not sure which unit it is its a 10 plate with the dynaudio , that sounds like it could work il give that a try thanks
Yes set aux input level to low and see if that works.
Had this with mine. Set it to low and now sounds a treat. I only noticed it when upgrading my speakers to focals though.
- whiteDevil_170
I was just playing about with EQ and then came across it. Changed it and noticed the difference straight away , sound was terrible. So quickly changed it back to low.
Jack
Lets Roc
Lets Roc
Check the Volume adjustment of all ur songs on itunes (select all..right click...get info) ... Keep the bar in the middle. Then sync the phone. Try it after
I got it thanks alot for the help !!!
It was the output was set to high , hence it being so crackly , thanks again
- whiteDevil_170
