After reading several topics on tyre wear problems with the rear tyres on the scirocco I came up with a question about the laser wheel alignment system which from previous experience with other cars is pretty good.
If by factory default the rear wheel camber on the scirocco is wrong which causes inner tyre wear then surely laser alignment will not cure this as the factory settings have to be input into the laser unit as a guideline, or are these systems intelligent enough to set the camber to a correct position.
My tyres are very worn on the inside and the road noise is quite loud so I would like to cure this when I eventually change the tyres.
On a plus note I love this car it is a drivers dream.
Great forum, keep up the good work.
![Clap :clap:](./images/smilies/clapclap.gif)
