Climate Control AUTO options
Hi, anyone know what the difference is between the two options on the AUTO button on the climate control unit. There's two lights on it, you can press it to light up either.
Re: Climate Control AUTO options
The difference between the 2 settings is the fan speed. If you select between the 2 you will see on the display that one has a small fan symbol and the other has a large fan symbol.
You can also see this on the fan speed LED array when you select between the 2 settings.
Thanks Cuprabob! I noticed that this morning on the display and had a Doh why didn't I notice that yesterday!
