7 speed DSG not running as smoothly between 1st & 2nd gear
- Gary_Monkey
Over the last month I've started to notice my DSG isn't running as smoothly as it once did between 1st & 2nd shifts.
It's hard to explain but there is a bit of a judder (and a slight surge) when changing from 1st to 2nd. It is especially noticeable at slow speeds (when crawling forward in slow moving traffic). All other gear changes are still smooth.
Don't get me wrong it isn't terrible but as all the other changes are practically indiscernible you kinda notice it more.
Anybody else experience this or has it been raised on here before and I've missed it.
What d'ya reckon. Trip to the stealers (which I hate) or just live with it? Still under warranty until Nov 2012.
Feedback welcome.
Gaz
Feedback welcome.
Gaz
Car Deliverd :-) 10 Nov 2009
Re: 7 speed DSG not running as smoothly between 1st & 2nd ge
Gary,
Dealers old boy.
Its a known problem with the 7 speed DSG, may also affect reversing as well. It will progressvely get worse.
New clutch pack will be fitted. (TPI 2026097-03 - 05.01.2012) plus they will update the DSG ECU with new firmware which gives quicker gear changes on all gears.
Dealers old boy.
Here in Greece we have a lot of 1.4 Rocs ...
I bought too a 1.4 DSG7 in January
In greek sciroccoclub the most members of a 1.4 DSG7 have the SAME PROBLEM , also all around the wolrd all DSG7 have the same problem(less problems at DSG7 i have seen at Polo GTI/Ibiza Cupra/FR/Fabia VRS/A1 185PS)
As RW1 said, VW Germany have new Clutch Pack for the DSG7 more realiable and also if you put the new Clutch pack you must update to the latest version .
I hope my Roc to have the new Clutch Pack and the new software .. so to have no problems . It is MY2012
RW1 you are veryyyyy old member and you have DSG7 . How many km. dou you have and what problems it appears to you?
How did you know it was my 82nd birthday in 17 days time ?the_winner wrote:RW1 you are veryyyyy old member and you have DSG7 . How many km. dou you have and what problems it appears to you?
Just coming upto 22,500 Km.
I have no problems with the DSG I can detect. In fact, shortening the spark plug gap took any away gear change effects. Just tweeking the Camshaft Adjuster Solenoid Valve to remove what remains.
Smooth as a baby's bum all the time and even better since the spark plug gap was reduced. Just like an electric motor now, never feel the gears causing surges, judders, etc..
RW1
do you have strange sound coming from the DSG(maybe) at rough road with open windows? Like cra crack clack cra crack clack ....
I have it from the day one but i ask other two people with brand new scirocco dsg and they have the same sounds ....
also i see that all guys with DSG7 have the same sound so i leave it alone ....
Do you have the sound?
Do you mean when the DSG changes gear or as its driving while in gear?
Something like this " onclick="window.open(this.href);return false; but in more rough road
exactly the same with this : " onclick="window.open(this.href);return false; but we have not so much rough roads so to be so loud. But at some roads its like this and its like an old crappy car
Do you have this sounds?
For example if i am with 3rd gear and low speed and i see a bump at the road i push the brake then before it downshift to 2nd gear i hit with my wheels the bump then the crappy noise
...Also sometimes i can hear the 1/2/3 gear change like clack clack but at rough road i hear TIN CANS like the video and with some search at google all have the same sounds but i dont know if it is a problem
I will have a listen tomorrow specifically. Not had the windows down all winter lol.
Have you had anything else happen? eg. DSG gear indicator in the MFD flash, engine stalling when switching on high electrical loads such as the Heated Rear Window, Headlights, Cabin Fan on full speed or no drive when D or R is selected????
Have you had the software upgrade in the DSG (Auto-Trans - 02 Controller)?
Goodmornung from the sunny Greece
Thanks RW1 for your replys , the car is new MY2012 39 built week I hope to have the new clutch pack and the latest DSG software !
I have 5500km and no problems ,no flashing gears , no shudder , only the annoying rattle with windows down at low speed on rough road with 1st,2nd and 3rd gear !
If you searc on google DSG rattle you can find that all have the same sound . The second YouTube shows the annoying rattle ! I ask two more friends with brand new scirocco dsg7 and they have the same rattle ! Please tell me if you have the same sound
As I wrote on the "Whats Your Build Date?" yesterday.....
DSG7 New Clutch Pack ........
Software. Post up a VCDS screen shot of your DSG Auto-Trans - 02 screen or an Auto-Scan list.
I will come back about sounds later. First indications - quiet
But remember I sit on the right side with the gearbox on the left.
Dated: 05.01.12..VW wrote: Production Change --
OK had the opportunity today to get to some rough roads. In D1, D2 & D3 at below 20 mph (30 Kph), cannot hear anything with the side window open. Not even the DSG changing gear (clack sounds).
Put a microphone in the engine bay on top of the battery and recorded the trip (1 hour). That picked up the DSG clack noise gearchanges. On the rough road part, all that was picked up was the suspension creeking. No noises like the YouTube link you say is best typical of it.
thank you very much RW1!
i ask the same questions at the Sciroccoclub.gr and some guys tell me that they have the same sounds even with MY2009 or MY2012 scirocco dsg7 also i ask and some guys with seat ibiza cupra/fr(dsg7) and they hear the same sounds ....
When i found time i will pick up my camer and i will record a video to show you .
As before can you provide the VCDS(VAGCOM) info requested above.
i dont have VCDS but why do you want the software part no? Does it play role to the rattle?RW1 wrote:As before can you provide the VCDS(VAGCOM) info requested above.
Yes software, yes it has effect.
I just received a letter from my VW SC asking me to book an appointment for 7-speed DSG update. I have the juddering in lower gears & I hope this update will fix that issue. However I am also concerned if it will cause the car to suffer a lag when pulling away from a standstill. Anyone has gone for the update? If so, I really appreciate if you can share your pre & post update experience... Thanks!
Hi. I have a jetta 1.4 tsi cavd engine with dq200 dsg. For what it's worth the issue of hearing gear changes 1-2-3 with windows down is known by VW and is listed in a tpi. Basically they say this is a comfort issue but not a component failure issue so they're not going to fix it as there is no fix currently. If needed I can post the tpi word for word as I have access to elsawin.
My main question is does anyone have statistics on 7 speed dsg issues?
I know I have the same engine and dsg as you guys but I don't know if my vcds scan would show different sw and he numbers fir my dsg but I'll post them anyway:
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 053 HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3029
Revision: 00043014 Serial number: CU501112056516
Coding: 0000020
Shop #: WSC 02069 000 90108
Coding: 0000020
Post the TPI if you can .
All DSG7 make sounds , it is very annoying . I have ask owners of Audi A1,A3, VW Golf/Polo/Passat, Seat Ibiza/Leon etc etc all they have the annoying sounds .
The most common problem in DSG7 is the Clutch Pack which make the car to Judder at the 2nd Gear . VW Have make new clutch disk and i hope to solve the problem for ever . Also the most scary problem is the Mechatronic
which when it goes off you cant move
"Technical product information Transaction No.: 2021120/2
Service info: transmission - gear changing noises/clacking Release date: 10-Dec-2009
Gear changing noises in position D in the first three gears. From second to third parties gear and with open window gear changing/clacking noises are clearly audible.
In the Tip gate the noises are less pronounced.
The noises are caused when a gear is selected.
That tpi occurs on any road. There is another tpi for the clacking and rattling noises on rough roads which is a software update. Will post that tpi word ..... ********
. They state no component failure in that one as well.
The one that I am most afraid of is the mechatronic unit failing suddenly.
