Climatic control Auto Switch function
aesmidz
Post by aesmidz »
I have the latest climatic AC System in my 2010 Scirocco
Does anyone know what the lights mean in the auto switch
The light in the left hand side of the switch is system on, but if you push the auto button again the light on the right hand side of the switch lights. What function is this? It's not in the handbook
RickG
Options: Black leather, parking sensors, flat tyre indicator, carpet mats
Re: Climatic control Auto Switch function
Post by RickG »
I might be wrong but I believe it increases the intensity that the fan will operate, with the second setting (right hand side light) being higher fan speeds. The graphic which appears on the touchscreen shows a bigger fan symbol to indicate your selection.
sciroccorocket
Options: Parking Sensors Pano roof Sat Nav
Post by sciroccorocket »
its means it will keep the car at whatever temp you set it at
Kev
Administrator
Post by Kev »
Yeah AUTO will automatically play with the fan speed and temperature etc to keep the car at whatever temp you've selected on the dial.
Didn't realise what you meant until I checked when I drove the car home tonight from work. Never noticed if you pushed the Auto button again the LED on the right comes on.
From what I can see it does what RickG says and alters the intensity of the fan. The left LED being a lower intesity than the right LED reflected in the display by a different size fan symbol
sciroccorocket wrote:its means it will keep the car at whatever temp you set it at
You may want to read the post again. It seems the Auto button has 2 settings. I have never noticed this until I read this post
Kev wrote:Yeah AUTO will automatically play with the fan speed and temperature etc to keep the car at whatever temp you've selected on the dial.
We know that but do what the OP says and push the Auto button twice
Deft
In: Indium Grey
Options: Rear parking sensors
Post by Deft »
Yeah it just tries harder to get to the set-point. It settles down once it gets there I think.
aesmidz
Post by aesmidz »
Thanks for the replies, I like to know how everything works!!
Reason: Caps lock off please :)
Rob
In: Salsa Red
Options: Scirocco's gone!
Post by Rob »
If you read your owners handbook it explains it all in there
