It's been a while and car looking dirty, so cleaned wheels, then rinsed, citrus pre-washed car, then rinsed, then washed & dried car, applied tyre dressing, then hoovered interior, wiped interior surfaces and brushed mats.
Updated the firmware on the new RNS I have installed in my car (v2840 - v3810); uploaded the new v10 maps; got the speed camera POIs off the internet and included those too!! Really pleased, love the RNS510 unit
- RavG99
How do i check the firmware. I got on my rns510 and how do I update if needed?dimexi wrote:Updated the firmware on the new RNS I have installed in my car (v2840 - v3810); uploaded the new v10 maps; got the speed camera POIs off the internet and included those too!! Really pleased, love the RNS510 unit))
Sent from my GT-I9505 using Tapatalk
Got a picture?as I have never seen one and the standard hole looks pretty rubbish :-(Dubvrs wrote:Retro fitted my Bluetooth this morning and coded it in. Works spot on. All done in less than an hour then fitted my golf mk6 covered ashtray. Looks so much better now.
If you are under warranty, talk to VW.RavG99 wrote:How do i check the firmware. I got on my rns510 and how do I update if needed?dimexi wrote:Updated the firmware on the new RNS I have installed in my car (v2840 - v3810); uploaded the new v10 maps; got the speed camera POIs off the internet and included those too!! Really pleased, love the RNS510 unit))
IF not, you can check it using VCDS. (Do a scan of the Navigation/Radio module and check the HW/SW numbers)
If not, you can take the unit out and check the sticker on it.
My advice - Do not upgrade the firmware if nothing is wrong with the unit... You know, if it aint broke, dont fix it
Removed my rear wiper and fitted blank.
Fitted my missing rear o/s arch spat.
Cleaned and waxed.
Cleaned and waxed.
- easyrider
i love the idea of removing the rear wiper, but can't resist using it to give people behind me a little 'wave' sometimes!
dubvrs how did you get the wiper arm off the motor? i haven't tried in a while but i could not for the life of me get it off :/ cheers
I used a wiper puller as a couple of people on here have had issues getting there's off.robb wrote:dubvrs how did you get the wiper arm off the motor? i haven't tried in a while but i could not for the life of me get it off :/ cheers
- In: Dark Oak
I washed my Scirocco this weekend, only to find that my neighbour had used a pressure hose to cleanout his garden path
So i can wash it again
- Andy Rocc
I did something i never want to do again in a hurry. Today with lots of help from my brother we fitted Eibach Pro springs a total nightmare, we are use to Vauxhalls so VW is a totaly different setup, we got there in the end though.
Also trial fitted a white stripe to the lower grill, can`t make my mind up on it though!
- whiteDevil_170
Strip looks good although part of me thinks the red gti look is better suited.Andy Rocc wrote:I did something i never want to do again in a hurry. Today with lots of help from my brother we fitted Eibach Pro springs a total nightmare, we are use to Vauxhalls so VW is a totaly different setup, we got there in the end though.
Jack
Lets Roc
- Phil
- In: Night Blue
Finally purchased a snow foam lance. Also put in my summer matts - is it too early?!?!
Phil
- whiteDevil_170
I never took mine out at all! I forgot lolphiljay92 wrote:Finally purchased a snow foam lance. Also put in my summer matts - is it too early?!?!
Jack
Lets Roc
- Andy Rocc
Whipped the white stripe off as it was bugging me, was too white compared to the body of the car so I'll be ordering a red stripe to see how that looks.whiteDevil_170 wrote:Strip looks good although part of me thinks the red gti look is better suited.Andy Rocc wrote:I did something i never want to do again in a hurry. Today with lots of help from my brother we fitted Eibach Pro springs a total nightmare, we are use to Vauxhalls so VW is a totaly different setup, we got there in the end though.
Also got my wheel alignment sorted of yesterday's Eibach fitting, surprised how much it was out!
- easyrider
where do you get the strips from, i need a red one too.
- Andy Rocc
EBay, the seller I bought the white from is called "stripeworld"
- easyrider
brilliant. thanks!Andy Rocc wrote:EBay, the seller I bought the white from is called "stripeworld"
- Andy Rocc
Order the 8mm oneeasyrider wrote:brilliant. thanks!Andy Rocc wrote:EBay, the seller I bought the white from is called "stripeworld"
Did my routine VCDS scan and cleared up a few non-priority errors that came about due to the RNS install. Hate driving around with errors on the system - OCD.
turned off my cornering lights via fog, and also the headlight activation at certain motorway speeds (I find it annoying)
