Marius Rocco
davidscirocco
Re: Marius Rocco
i have check to see what requirements i need to make the high beam assist and i dont have the camera back of my on my center mirror. so even if i wanted i need to retrofit that camera...
- Roy_01
Re: Marius Rocco
Oh stupid i forgot, then you are right uncheck it.
davidscirocco
Marius336
Re: Marius Rocco
there is a high beam assist without camera, you know?
you dont need to do the Passat camera to have high beam, there is a light diod one
davidscirocco
- Roy_01
Re: Marius Rocco
You mean the light assist rear view mirror?
Marius336
Re: Marius Rocco
yes ,
1k8857511b
there is a kufatec harnes for that, only work MY +2010 with BCM
1k8857511b
davidscirocco
Re: Marius Rocco
i have seen a video on youtube someone retrofitting this. i think you have to change the 6 pin connector to 8 pin and have to connect canbus cable from the mirror to the canbus AFS module and then there are some coding and thats it. correct me if im wrong
- Roy_01
Re: Marius Rocco
Just connect to the can gateway, but the rest is right easy swap.
davidscirocco
Re: Marius Rocco
Will think about it. Im going to change the headliner so maybe ill just pass the cable and when i need to change it will be an easy change
Marius336
Re: Marius Rocco
yes, change 6 pin plug from mirror to 8 pin
Niqlai
- In: Night Blue
Re: Marius Rocco
Hello mate.
Have you bought the car with side assist, lane assist, park assist and so one or have you done that your self ?
Marius336
Re: Marius Rocco
all by my self, these things you cant get from VW for Scirocco, only in Passat.
Niqlai
- In: Night Blue
Re: Marius Rocco
I will sent you a PM
Steve_MCG
Re: Marius Rocco
Hi Marius, I seen your Retrofit of MIB2 to your Scirocco, did your unit have the CP removal done on the motherboard? Is the canbus gateway necessary for retrofit? I have been looking to do this retrofit for some time and have not found a lot of information on how to do this with Sciroccos. Any help appreciated and you car looks awesome!
Marius336
Re: Marius Rocco
i got a new DM and Tim from VCDSWorkx did the Component Protection direct to my 3D Cluster. So my Component Protektion is aktiv like in Real Facelift Scirocco.
Gateway is not realy nessesary, but i recomand to et a gateway that support 5F
Marius336
Re: Marius Rocco
For more information look at Lane & high beam assist & fatigue detection installed
- Roy_01
Re: Marius Rocco
Very nice job Marius, if VW sees this they hire you directly
Marius336
Re: Marius Rocco
i study car engineering in Wolfsburg
- Roy_01
Re: Marius Rocco
Then it makes sense haha.
