SCIROCCO 2011 Facelift done
Argonaut
Options: R-line exterior, "Edition" version which means black roof with panoramic window and special sport seats.
Re: SCIROCCO 2011 Facelift done
Post by Argonaut »
Marius336 wrote:your LED DRL dim from DRL to parking light?
No because I run on old BCM, on the 087AB BCM it would only work.
I had that bcm but it was for keyless - trash
Marius336
I drive a: 1.4 TSI 122/125
Post by Marius336 »
i have 087 AB but dont dim
BCM was new and Bit 18 was set manualy, no scirocco preset
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Post by davidscirocco »
i have 087 AB and i think mine dims
Roy_01
In: Sumatra
Post by Roy_01 »
What dimming setting do you have in VCP, 2? And in VCDS byte 24?
davidscirocco
sport pack
RCD 510
i must check but the bcm was taken out from a vw scirocco R facelift so i almost did not change anything from coding. i didnt even need to do anything with vcp for the tail lights because it was already coded
Roy_01
In: Sumatra
Post by Roy_01 »
Can you post a scan of your module 09 coding?
Interested in your settings. You were lucky with that Scirocco R facelift bcm.
davidscirocco
sport pack
RCD 510
Roy_01 wrote:Can you post a scan of your module 09 coding?
i will post tomorrow :yes: i have obdeleven, is there something specific you want to see on module 9?
i really am lucky thanks to you :)
Roy_01
In: Sumatra
Post by Roy_01 »
Only the coding of the bytes of module 09 , the long coding.
Your welcome, i also had a lot of help of others on this forum ;)
davidscirocco
sport pack
RCD 510
ok will sent the long coding tomorrow :)
Jason1
In: Pure White
Post by Jason1 »
Do you have part number for the caps on the front bumper under the headlights.
davidscirocco
sport pack
RCD 510
ok here are my long coding that you ask.
my led strip on the headlight dims when i turn on my headlights. when i turn off my headlights my DRL gets brighter. is that what you wanted to do too?
Roy_01
In: Sumatra
Post by Roy_01 »
Yes that is what we want :) Thanks David!
davidscirocco
sport pack
RCD 510
after all the help i needed from you im glad i can be handy :)
Roy_01
In: Sumatra
Post by Roy_01 »
Good job :) The difference between us is that you have checked:
Byte 11 bit 6
Byte 16 bit 3
Byte 17 bit 1 & 2
I cant remember i setup dimming with vcp lol.
davidscirocco
sport pack
RCD 510
have you try to see if it dims now?
Argonaut
Post by Argonaut »
Wow thank you David you really helped. If only my AB module was right I would have had it coded right. You were lucky when you got that BCM, they are hard to find in general.
Stay tuned for updates on the car, I have something nice :)
Argonaut
Post by Argonaut »
As some of you may already know, when I had done FL conversion I was unable to get an R line rear bumper at that moment...
I got it on ebay recently and could not resist to get it painted and on the car. How sick I actually am? I painted matte plastic diffuser gloss black just like I did on the first one and got my front bumper off for a respray because it had a looooot of stone chips due to previous painter's mistake... :grumpy:
My opinion for the end: car looks much more buff now! Looks wider and gives much stronger impressions... I never thought these subtle differences would give this much better look + my GF agrees :)
  • Costed me:
:worthless:
nlscirocco
Options: Cruise control/
Post by nlscirocco »
Are the facelift rear parking sensors working?
Roy_01
In: Sumatra
Post by Roy_01 »
Wow it’s beautiful!
Argonaut
Post by Argonaut »
@nlscirocco no, they don't work because I don't have that optional extra. Sensors are just there to fill the holes for now.
@Roy_01 thank you man! Told you I had something big :)
