Roy_01
In: Sumatra
Post by Roy_01 »
Updated the polar fis advanced to V0.4.8.
http://www.auto-polar.com/forum/showthr ... -functions" onclick="window.open(this.href);return false;
selleym
Options: Mirror Pack
Mods:
Bonnet Struts
Metal Pedals
Post by selleym »
Was on red so had to drive economically.
Managed to get 46+ mpg on the way to the petrol station.
Was the most boring drive ever though lol.
Got 32 mpg on the way back :clap:
Roy_01
In: Sumatra
Post by Roy_01 »
Increased the idle rpm with vcds today. 780 to 830 rpm.
tommy
Options: 19" Lugano anthricate alloy wheels
DSG gearbox
Cup Spoiler
Heated leather seats
VR Cold-Air intake
BCS Full Turbo Back 200 Cell Sport exhaust with black ceramic tips
RNS-510
Ecotech Performance remapped
Forge big brake kits 6 pots 356mm front
Forge big brake kits 4 pots 330mm rear
Post by tommy »
bank holiday to the beach! :lol:
Psycho Kirky
In: Salsa Red
Options: MODS-
K&N Typhoon Induction kit
BCS Powervalve custom sport TBE
REVO Stage 2 remap
Airtec Stage 2 Intercooler
Forge diverter/recirculation valve
Sachs Performance clutch
'Heavy Set' silicone hoses
REVO Torque Mount Insert
Various detailing
Post by Psycho Kirky »
Roy_01 wrote:Increased the idle rpm with vcds today. 780 to 830 rpm.
Just out of interest what is the benefit of increasing the idle rpm? Cheers.
Sent Via tapatalk
Roy_01
In: Sumatra
Post by Roy_01 »
I heard people who had some trouble with low idle rpm's so i was looking for a way to change the idle in vcds. I didn't read anything about it on the newer CR and TSI engines but it is possible.
Probably gonna change it back because it was running already very smooth on 780 rpm.
It was just a try out;) You can find a how to in topic:
http://www.sciroccocentral.co.uk/forum/ ... =2&t=20123" onclick="window.open(this.href);return false;
Shaun1982
Post by Shaun1982 »
I bought a Bluetooth unit finally. Fingers crossed it all works as I hope lol
Douggie1233
Post by Douggie1233 »
Played around with Vagcom last night. Got the PRL's turned off, beep on lock/ unlock, needle sweep and re-coded the rear number plate lights to accept LED's.. Couldn't get the big speedo on the MDF to work though.. -_-
Jojreynolds
Options: Recaro seats, rns 510, power fold mirrors, pano roof, full LED interior, LED puddle lights
Post by Jojreynolds »
Douggie1233 wrote:Played around with Vagcom last night. Got the PRL's turned off, beep on lock/ unlock, needle sweep and re-coded the rear number plate lights to accept LED's.. Couldn't get the big speedo on the MDF to work though.. -_-
Hi mate, deactivate alt speed display in the mfd and big speedo should appear :)
Instagram: James.reynolds
Douggie1233
Literally just figured it out. Cheers anyway though!! :D
Shaun1982
Post by Shaun1982 »
I'm just playing vag com for the first time. Doesn't look like I can do the needle sweep on my 59 plate with white mfd.
When you do the big Speedo mod does it change your odo & trip to kms instead or does it stay as miles please?
Irvysan
In: Ultra Violet
Options: MY15 2.0TDi (150PS), 90% rear tint, Electric folding mirrors, Vienna leather, RNS315.
Retro Fitted : LOTS of plasticky bits from china and well since I ran out of characters for this bit look here : http://www.sciroccocentral.co.uk/forum/ ... 13&t=19967
Post by Irvysan »
Shaun1982 wrote:I'm just playing vag com for the first time. Doesn't look like I can do the needle sweep on my 59 plate with white mfd.
Hi Shaun,
Have a look at this post : http://www.sciroccocentral.co.uk/forum/ ... 41#p169941" onclick="window.open(this.href);return false;
Yes initially it does change it to kmh but you just need to change the units via the MFD
Sent from my LG-D855 using Tapatalk
Shaun1982
Post by Shaun1982 »
Yes,cheers mate, once it's stopped wee wee'ing down I'll go back out & have another play. I activated window closing but it doesn't seem to work & the inside got wet lol
Irvysan
In: Ultra Violet
Post by Irvysan »
This info may help : http://www.my-gti.com/204/volkswagen-go ... nd-sunroof" onclick="window.open(this.href);return false;
Ignore the coding but read the text, AFAIK the requirements are exactly the same for the ROC's . I didn't bother to enable it as I'm unlikely to leave the windows down when I'm locking the car.
Shaun1982
Post by Shaun1982 »
Thanks man, couple of reasons why then, didn't wait two minutes as it was already raining & my interior sensors were on.
Seems I've flattened the car enough to just not start, or at least I'm hoping it's that & not my messing with vagcom lol
Irvysan
In: Ultra Violet
Post by Irvysan »
Very unlikely to be VAG com. I was wary of that when playing with it, made sure the radio, all lights and fans were switched off as the battery can die pretty quickly with these on and the engine off.
Shaun1982
Post by Shaun1982 »
I don't think t be fact it's not moved in nearly a week helps either [THUMBS DOWN SIGN]
Irvysan
In: Ultra Violet
Post by Irvysan »
That's not going to help if you go and sit with the ignition on!! [emoji12]
Shaun1982
Post by Shaun1982 »
Most definitely not. Panic over though thankfully. Got my dad to pop round with jump leads. Ended up with esp fault on the dash but that disappeared by the time I got out the drive. Gotta say though the car sounded like something was loose & flapping around on tick over, I'll be keeping a close eye on that as it wasn't doing it before it went to Vw last Thursday!
Irvysan
In: Ultra Violet
Post by Irvysan »
Doesn't sound great! Hopefully nothing major.
