BAIKAR wrote:kodo28 wrote:The 3M1 part number doesn't existe at VW, I don't know here this part number came.
The retrofiting cable for scirocco doesn't exist, that's mean the cable for rear camera is included on an Master Central Cable on car...and to get the rear camera cable you need to change this master central cable. On Etka side no mention about witch cable it is
So to get this central cable a call from your VW dearler need to be done to the VW factory and ofcourse you will be asked to give your VIN number to see if your car came it rear camera before. And for sure this cable will cost you some money
The only possibility is on Kufatec side, cable will be available in 2 weeks
http://www.kufatec.de/shop/product_info ... rocco.html
Hope all this information could help some of you
So forget the 3M1 part number...this number is not an VW number :mad:Kodo28
Looking at the link for the cable from kufatec this is the same as the cable you purchase from a dealer. You must also order the camera separately and no where does it mention a wiring loom for the camera. Before ordering I would ask them if there is any additional wiring necessary?
Like I said the retrofiting cable for the Scirocco camera (1K8) doesn't exist for remplacement at VW so you can not find it on dealer. The cable for camera is together with a central master cable on car, so if you want to have it you need to change the master cable.
To fit the Original Scirocco Camera 1K8.980.551 you will need :
Camera Scirocco OEM - 1K8.980.551
Cable From Kufatec - Available in 2 weeks
Support for camera - 3W0 807 210 B GRU
Cover for the Support camera (bentley Part) - 3w0 807 151
4pin connector 3B0 972 722
repair wire - 000 979 131 x4
To fit the Golf dumper Camera on you Scirocco you will need:
Camera Golf OEM 5 K0 980 551
Cable 5M1 970 161 AC
repair wire 4x 000 979 131
And that all!!!
