Squeaky window seals
Re: Squeaky window seals
then your not using a quality silicone spray the Rocol spray lasts for months
- selleym
Sorry for dragging up another old thread
But the squeaky window seals when opening is driving me crazy!
Is this the correct one to get? Doesn't say it it has an applicator.
http://www.amazon.co.uk/SONAX-GummiPfle ... roduct_top
Also do you apply it to both the outside of the seal and the inside where the window goes in between the rubber?
- Kev
- Administrator
Yeah that should do it.
The applicator is the top of the bottle. When you take the lid off there's a sort of spongy plug in the top and it seeps through that as you apply it.
I just ran mine along the glass and it seemed to work fine.
- selleym
Arrived today and its a solid stick like a pritt stick sorta thing....
Guess it will do the same job?
It's not like a Pritt Stick other than the shape. It's full of fluid and when you remove the top there is a felt applicator pad.selleym wrote:Arrived today and its a solid stick like a pritt stick sorta thing....
- selleym
No i'm saying the one i have is actually is like a pritt stick. Its a solid stick you push it up from the bottom... No liquid in it
Its the amazon one in the link in earlier post.
Apologies, that's different to the one I have then.selleym wrote:No i'm saying the one i have is actually is like a pritt stick. Its a solid stick you push it up from the bottom... No liquid in it
This is like the one I have;
http://www.amazon.co.uk/gp/aw/d/B007TNO ... ot_redir=1" onclick="window.open(this.href);return false;
- selleym
Ahh hoping it does the job just as well
Translation of whats on the tube if anyone was interested.
£5.91 + £4.35 UK delivery For the other oneRubber Care Stick.
With deer.
Nourishes and protects rubber against brittleness. For car and household. Contains vaseline.
Prevents winter sticking of rubber seals on doors, windows and trunk lids. For ease of processing the closed SONAX GummiPfledgeStift before applying heat with your hands. Both sides thinly on the rubber seals, remove excess material with cloth.
I bought mine a few years ago direct from.Einszett for around £7.99 delivered.
- selleym
Will see if this stuff works first. Hopefully it does! Otherwise will have to get some of that Einszett one.
- selleym
Update:
Seems to work. Leaving a smear at the top of the window for now but that's probably just excess stuff.
Will have to give it a proper going over later. Real test is how long it will last
But squeaky windows gone for now
Update 2:
Only works for a few days then starts squeaking again....
Update 2:
- keal23
Would the Einszett Gummi Pflege work with the squeak with the windows going fully up and down?
Mines starting to devlop a squeak occasionally when im closing my drivers window.
Or is it just for the inital drop when the doors open?
My Progress
http://www.sciroccocentral.co.uk/forum/ ... 13&t=16773" onclick="window.open(this.href);return false;
Instagram - keal023
Instagram - keal023
- selleym
Mine squeaked when doing fully up and down as well. Which seems to be fixed from using the Gummi Pflege.
As there is a rubber seal on one side of the window that runs all the way up.
If the noise is coming from the window rubbing on seal it should cure it.
But it could be coming from inside the window mechanism like something stuck in the runners.
Is it just one or both of the windows?
- keal23
Thanksselleym wrote:Mine squeaked when doing fully up and down as well. Which seems to be fixed from using the Gummi Pflege.
Pretty certain its not the mechanism and just the rubbers, only happens on my drivers side window.
Ill get some ordered and give it a try
My Progress
Instagram - keal023
Instagram - keal023
- selleym
DONT buy this one if ure having squeaky window seals!!!
Its fine for treating normal seals!
But because its a solid stick it leaves a slightly sticky residue! Which means it doesn't help with the seals that the windows slide over! Works for about 24 hours until it dries then it squeaks again!
Just a warning to others!
- selleym
Took it to the VW garage at the weekend just talking to the mechanic about a few rattles. Told him about the rubber seals squeaking and he just went and got the VW rubber treatment stuff.
Treated the seals for me for free in the car park and i am squeak free for now ...
My Roc is going to VW on thursday as my rear left tire makes a loud clicking noise around 75mph....has anyone experienced this before?
Do you know if I need to buy Gummi Pflege or if VW will just fix it for me?
Thanks!
Thanks!
Hey folks - what's the verdict on this one then? I'm having the exact same squeaky window problem and it drives me nuts, but it looks like there are some mixed reports as to what works as a long-term fix and what doesn't really work at all!
I've heard that Autogylm Silicone Spray can work: http://d.pr/WCfm as well as Autogylm Vinyl and Rubber Care: http://d.pr/AtO7
Then again I also heard the Sonax GummiPflege stuff was great: http://d.pr/Bler - but the reviews on here don't look so good!
What do you guys recommend?
Cheers!
Cheers!
Thanks for dragging up this thread, my squeaky windows are beginning to make me twitch a bit. I will try the Gummi stuff and see how I get on. Will buy it off ebay and make sure I have the correct one.
Plenty of info on page 1 of the thread
If you can't wait than Halfords Silicone Spray worked for me, costs about a fiver. Also keeps moisture out which helps prevent the windows icing shut in winter. I've used it on all the frameless windows cars I've owned, without any problems.
