I have the exact same problem as just had a new regulator fitted and all works fine going up and down but the auto drop when opening or unlocking the door won’t work?
Can some one please help as even the garage is struggling to find the fix?
Window wont go down so door can be opened/closed
- Roy_01
Re: Window wont go down so door can be opened/closed
You have to code the module for frameless doors.
Hi I am having the same problem but instead my wing mirror is showing no life such as indicator isn’t flashing it won’t move and the heater isn’t engaging I have changed the module and checked the fuses but all looks good
