Will be able to connect the camera cable from the Golf to the camera of the Scirocco making change in the cable pins if possible what changes have to do...?
Thanks.
I already have the camera's original SCI I dont have the cable to conet the camera to the RNS i can´t get the cable 3M1 making changes in the cable 5M1 may i be able to make the job.
Excuse my English Thanks
Shadow_Blue wrote:I already have the camera's original SCI I dont have the cable to conet the camera to the RNS i can´t get the cable 3M1 making changes in the cable 5M1 may i be able to make the job.
Option 1:
Return Scirocco Camera
Buy Golf 5 Camera & Golf 5 cable
Option 2:
Buy Golf 5 cable and cut cable and solder it onto Scirocco camera.
Can not return because they offered me two I'll have to buy the plug that connects to the cable Scirocco seen the plug of the chamber is different.
And how I remembered it thanks again
I've been asking in another topic about updating my rcd to the latest rns. However I've seen various ones for sale and I can't see the necessary connection for the rear view camera which I plan to do also. Can anyone tell me what I should be looking for so that I can add the camera at a later stage.
BAIKAR wrote:I've been asking in another topic about updating my rcd to the latest rns. However I've seen various ones for sale and I can't see the necessary connection for the rear view camera which I plan to do also. Can anyone tell me what I should be looking for so that I can add the camera at a later stage.
All the RNS's should be able to take the camera with the right Firmware, however i would personally prefer to have the latest C version with the star button and new screen.
The right firmware? Did yours have the connection on the rear for the camera? I know the screen is better on the latest versions but what's special about the star button?
BAIKAR wrote:The right firmware? Did yours have the connection on the rear for the camera? I know the screen is better on the latest versions but what's special about the star button?
Nothing is better about the button, its just a way of spotting the better screen C version , ps mine has the connection for the camera, every genuine RNS510 should have the connection for the camera, for firmware if you get the latest unit it will have the right FW on it.
Thanks for that. One other thing. Can someone explain the confusion over the two choices of camera, either golf or scirocco. Why would anyone have ordered the parts for a golf when there are specific part numbers for the scirocco?
I too have tried to just order the 3M1 aerial lead and it is not a part number available to order directly. Anyone thinking of this project should just stick to ordering the golf one to save anymore confusion.
Just received my 3w0 parts and I've just tried a first fit. Cant seem to fit the camera in the holder then attach the clip to hold the camera in place. There are two plastic cylinders on the back of the camera that stops the clip going far enough into the holder for it to catch. Do you have to drill holes in the clip or cut the cylinders off the camera?
