*.* Scirocco R Build! (Fun, Tough & Cost) *.*
Mostic
In: Oryx White
Options: Let's wait until I start the mods :)
Re: *.* Scirocco R Build! (Fun, Tough & Cost) *.*
Post by Mostic »
Okay, here are few updates;
I started to work on the Quattro project...
Preparing for the AWD.
Open the second hole for the tank.
Covering the welding.
Close to finish.
Haldex installed and coded [emoji1360]
Then as all projects you should have a problem that complicate it [emoji116] [emoji57]
ABS error;
I checked similar project who had the same issue, but he changed the cluster from Scirocco and replaced by Golf R one.
Here is his comment[emoji116]
“However, the conversation gradually drew the attention to the fact that the ABS control device is so "crooked" that it listens the vehicle model / type code sent from the CAN bus to the instrument panel and does not encode the conflicting type code itself. That is, when the instrument panel claims a car to Scirocco, the ABS control device does not allow it to encode itself to Golf. And Scirocco can't be a four-wheel drive. On the instrument panel, that type is "hard-coded", but it cannot be changed by VCDS.”
I believe if the Scirocco instrument cluster changed from FWD to AWD then the ABS fault will disappear. I don’t know how yet but hopefully will figure it out, all support are more than welcome :)
Stay tuned, more is coming [emoji6]
http://www.sciroccocentral.co.uk/forum/ ... 13&t=21372" onclick="window.open(this.href);return false;
MKV Build!
http://www.golfmkv.com/forums/showthread.php?t=195173" onclick="window.open(this.href);return false;
Roy_01
In: Sumatra
Post by Roy_01 »
Wow great progress, almost finished i see!
I would also swap the cluster, it makes sense what you wrote.
Mostic
In: Oryx White
Post by Mostic »
Roy_01 wrote:Wow great progress, almost finished i see!
There are two problems to swap the cluster; first one that I don’t have the Golf R one, second that I have the new Scirocco 3D cluster and I want to install it very soon once I finish the swap
Here are pics of the new 3D Scirocco cluster
That’s why I need to find a way to fix the ABS fault while having the new Scirocco 3D cluster installed :(
MKV Build!
Alien_IROC
Options: ....IROC project....
@vw_iroc_project
Post by Alien_IROC »
Wow! Do you have taken picture of the 4motion installation? The rear powertrain and haldex....
For the ABS problem, perhaps is possible to recode the cluster with some advanced tacho programmer tool....you need a very skilled VW expert!
Mostic
In: Oryx White
Post by Mostic »
Alien_IROC wrote:Wow! Do you have taken picture of the 4motion installation? The rear powertrain and haldex....
I have video of it, I will upload it soon.
Yeah, cluster need to recode and I will see how to do it
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
Here is the AWD video.
https://vimeo.com/317987684" onclick="window.open(this.href);return false;
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
Mission accomplished!
Just few modifications in the suspension and bushing then I can drive it. Unfortunately, it will be with the K04 turbo instead of the BT for the time being but at least a serious step is achieved.
MKV Build!
Alien_IROC
@vw_iroc_project
Very good! So how have you resolved the ABS problem?
Mostic
In: Oryx White
Post by Mostic »
Alien_IROC wrote:Very good! So how have you resolved the ABS problem?
The cluster has to be patched to change from Scirocco to Golf with a golf chassis VIN too then the ABS coded.
I believe that the problem coming from the cluster because it sends the signal that it’s a Scirocco and the ABS can’t accept the AWD that coming from the Scirocco because there is no AWD Scirocco. Once it’s changed to Golf the ABS accepted the coding.
I want to try if changing the cluster itself from FWD to AWD would help and fix it not. I had similar issue with my MKV when I was trying to install a cluster moved out from R32 to my MKV GTI. The ABS didn’t accept coding until I changed the cluster from AWD to FWD.
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
Quick updates;
New Ultra Racing Bars
And 3D cluster [emoji7]
More is coming very soon [emoji6]
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
3D cluster is working fine
MKV Build!
Cthuluawaits
Options: Stage 2
Post by Cthuluawaits »
Do you have any info on wiring up the fuel pumps?
Mostic
In: Oryx White
Post by Mostic »
Cthuluawaits wrote:Do you have any info on wiring up the fuel pumps?
You can find it in ELSAWIN. My mechanic use it to do all wiring installations.
MKV Build!
Cthuluawaits
Options: Stage 2
Awesome thanks!!
Mostic
In: Oryx White
Post by Mostic »
What’s is the best coilovers used for Rocco?
Most probably I will change my VWR coilovers because they are very bad and noisy while I drove them for few KMs!
I found the below coilovers on USP:
https://www.uspmotorsports.com/Volkswag ... Coilovers/" onclick="window.open(this.href);return false;
Want to know your opinion
MKV Build!
Roy_01
In: Sumatra
Post by Roy_01 »
Amazing new mod, totally new car.
Mostic
In: Oryx White
Post by Mostic »
Roy_01 wrote:Amazing new mod, totally new car.
The car becomes completely different and I like it more now, specially the handling and there is no slip at all. I don’t know how it will behave with BT but I believe it will behave better than the FWD :)
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
Question
I want to install the MIB II Discover Media (Radio) to Tiguan and Sirocco too. I am afraid of the Component Protection (CP) issue.
I heard that it can be removed from the Odis or maybe by another SW coding way.
I appreciate your help.
MKV Build!
Mostic
In: Oryx White
Post by Mostic »
Changed the VMR wheels today to the Audi 19” one.
I like the VMR more [emoji20]
Most probably I will paint the Audi wheels maybe I will accept it!
MKV Build!
finetrond
Post by finetrond »
is gona take a lot of paint to make the Audi wheels look better than the WMRs
Collector of warning lights.
