Bagged Scirocco from Finland / / Facelift
Jimijokela
Options: Airlift Performance suspension, Work Emitz 10"x19", 10.5"x19", R-bodykit and exhaust, Mk7 flat bottom steering wheel, remap, carbon interior, fully working Facelift R bi-xenons.
Re: Bagged Scirocco from Finland / / Facelift
Post by Jimijokela »
More...
Untitled by Jimi Jokela, on Flickr
llweemanll
Options: Stage 1 Engine + DSG
Volkswagen Racing admission kit
Full LED inside
Ceramic carpro
Post by llweemanll »
I'm french so i'm sorry in advenced for my bad english language...
I have a Scirocco R from 2010 and i would like to install the new facelift xenon.
The Xenon work but the LED doesn't work...
I have a vagcom and follow this tuto http://forum.vw-scirocco.fr/viewtopic.php?f=41&t=16260" onclick="window.open(this.href);return false;.
Can you help me for connection please because it's not the same connection to standar scirocco... ?
sc cal
I drive a: 1.4 TSI 122/125
Post by sc cal »
I installed the facelift xenons using the same tuto on a reg 1.4 tsi rocco and everything is working , i would double check your wires, module and coding
llweemanll
Full LED inside
Ceramic carpro
Yes but on the Scirocco R it's not the same connecting for the terminal. I do this on my old scirocco TDI 140 and everything was ok !
So if someone do this install on a Scirocco R please help me :)
llweemanll
Full LED inside
Ceramic carpro
Jimijokela can you help me please ?
Jimijokela
I dont know how to on scirocco r.. But only difference on the r is the blinker in the headlight..
llweemanll
Full LED inside
Ceramic carpro
Oh sorry I thought you had a scirocco R... Yes it's not the same connecting... :(
llweemanll
Full LED inside
Ceramic carpro
Where can i buy rear facelift ?
llweemanll
Full LED inside
Ceramic carpro
UP :)
Roy_01
In: Sumatra
Post by Roy_01 »
Is your headlight drl stil dimming when the dipped beams are on after joining pin 10 and 12 together?
And is the static cornering light controlled by the canbus? I see no pins in the headlight connector on pin 13.
Philuk
In: Opal Silver
Options: Winter pack, heated seats, headlight washers, puddle lights,
Post by Philuk »
That's stunning mate,
:clap:
Prefer the new wheels they seem to suit it better
llweemanll
Full LED inside
Ceramic carpro
Roy_01 wrote:Is your headlight drl stil dimming when the dipped beams are on after joining pin 10 and 12 together?
You think i have to join the pin 10 to 12 ? I don't retry to connect the new headlight. I will try this this week i know.
kazas
Post by kazas »
Hey thinking about getting rs5 rotors too....i have the s5 rotors 19x9 currently. U reckon u can run them on kw dccs? Or u need bags?
Mostic
In: Oryx White
Options: Let's wait until I start the mods :)
Post by Mostic »
Hi mate,
What is the part number for the facelift headlights?
I need it for LHD
Thx
Scirocco R Build! (Fun, Tough & Cost)
http://www.sciroccocentral.co.uk/forum/ ... 13&t=21372" onclick="window.open(this.href);return false;
MKV Build!
http://www.golfmkv.com/forums/showthread.php?t=195173" onclick="window.open(this.href);return false;
irocman78
Post by irocman78 »
hi Jimijokela
I'm going to mount 9x20 et 35 Rotor (no original)
I see you mountain 9x 20 et 26 (audi original) !!
I tried through Offset configurator but it seems impossible. Or you have to tilt the wheels
Now other other circles 20x 8,5 ET 44 !!
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#" onclick="window.open(this.href);return false;
do you know anyone who mounts Rotor ET 35?
Sorry my english is not good.
Mostic
In: Oryx White
Post by Mostic »
irocman78 wrote:hi Jimijokela
I have VMR710 ET35 18x8.5 and fitted without any problem
MKV Build!
irocman78
Post by irocman78 »
hi, Mostic ...yes, any problem for 8,5 ET 35.... but 9 ET 35 , who mounts other wheels ?
I would like to go to Rotor 9 x 20 ET 35 (not Et 26 - Jimijokela) deep concave but I think we are not in the fender
irocman78
Post by irocman78 »
Jimijokela wrote:More...
Jimijokela,
you have a photo high 1 or 2 cm high from wheel arches ?
