Marius Rocco
rikkky243
I drive a: 1.4 TSI 122/125
Options: Sport Pack, Mirror Pack, RNS 510, Interlagos 18"
Re: Marius Rocco
Post by rikkky243 »
Cool! ;) now with quarantine you can work more on this project, we have to think positive ahah
Alien_IROC
Options: ....IROC project....
@vw_iroc_project
Re: Marius Rocco
Post by Alien_IROC »
Super project! Also a manual gearbox CDL, very rare!
What turbo did you install? A new K04 or bigger?
Marius336
Re: Marius Rocco
Post by Marius336 »
new K04 because it had play inside the turbine
Alien_IROC
@vw_iroc_project
Re: Marius Rocco
Where you have bought it from? I'm thinking to go stage 3 on my 2.0 TSI....
Marius336
Re: Marius Rocco
Post by Marius336 »
http://www.ladermanufaktur.de/" onclick="window.open(this.href);return false;
Alien_IROC
@vw_iroc_project
Re: Marius Rocco
Thanks!
jpsc
In: Salsa Red
Re: Marius Rocco
Post by jpsc »
Hello Marius very nice Project
maybe you cam help Me
i have a 2010 Scirocco and a want to change my Steering Wheel What i need to do that?
I have this one:
And want to change to that one:
I made the change but only 2 buttons work the others not.
Can you help me?
Dreamer
Re: Marius Rocco
Post by Dreamer »
You may have to change the slip ring controller and then code it to your car. Make sure you do an autoscan and save it using VCDS.
Then you may need to code it assuming your car will accept it
jpsc
In: Salsa Red
Re: Marius Rocco
Post by jpsc »
do you mean
need:
1K0-959-653-C or 1K0-959-653-D
and you need new Steering controll module:
1K0-953-549-CD/CH/CK
Dreamer
Re: Marius Rocco
Post by Dreamer »
Potentially yes. You will to research it
Marius336
Re: Marius Rocco
Post by Marius336 »
with 1k0 steering module you need modification to the button to make the light work
with 5k0 Steering module wheel should be plug and play
jpsc
In: Salsa Red
Re: Marius Rocco
Post by jpsc »
Many thanks Marius
the lights in the new steering wheel works fine and two buttons, the rest did not.
can be a configuration problem?
Marius336
Re: Marius Rocco
Post by Marius336 »
Dont know with 1k0 steering module, only did 5k0 steering module so far
Marius336
Re: Marius Rocco
Post by Marius336 »
Fitted electric seat
Roy_01
In: Sumatra
Re: Marius Rocco
Post by Roy_01 »
Nice! What is the function of that button on top.
Easy entry?
Marius336
Re: Marius Rocco
Post by Marius336 »
Yes, the seat have a easy entry module.
It remeber the position were the seat was befor folding, yust like the mechanical seat. its some kind of memory function
Marius336
Re: Marius Rocco
Post by Marius336 »
Engine is in, and runs, yust need a bit wirering work, bacause my car had start stop funktion from factory, that needs to be removed, so the engine can start normal. Now it starts on ignition and without cluch :eek:
Marius336
Re: Marius Rocco
Post by Marius336 »
swap done, car drives amazing :D
Roy_01
In: Sumatra
Re: Marius Rocco
Post by Roy_01 »
Impressive, what a nice workplace you have there.
Enjoy your new engine! How much power does it have?
Marius336
Re: Marius Rocco
Post by Marius336 »
The GTI i pulled the engine of had Stage 1 Tune to 310 HP but my ECU got Flashed to CDLK Scirocco R facelift with 280 HP, But with the Scirocco Facelift Flash, my Boost gauge show the right data :D
