Open Module 76 – Park Assist:
Electronics 1 | 76 - Park Assist
Then select Coding – 07 and enable Bit 4 of Byte 0 (with correct labels you can Enable "Optical Illustration active"):
Optical Illustration Active
Then goto Byte 2 and select the correct Model:
Retrofit new MIB into older RNS/RCD car.
Re: Retrofit new MIB into older RNS/RCD car.
First 3 Bytes in 5F ( Composition/Discover Media)
02 63 04
02 63 04
- Dreamer
Ignore my advise. This was for RNS510 not the Discover Media. My badDreamer wrote:Open Module 76 – Park Assist:
That’s great thanks, will give it a go. Thanks for the quick replies.
space walker
can you explain how to remove the component protection on a car that didn't have it from factory as i am striking out i have a vcds and am able to reset the radio through the address 5f but the dealer said odis 5f was grayed out
I have a very good idea how CP can be removed. I will try and let you knowMostic wrote:Hi,spacewalker wrote:if car belong to Component protection remove online - dealer can do that easyblscargo wrote:Hi
I have a few questions about this process after you coded the radio in your friends caddy did the component protection ever come back and do you know how they coded it in you friends caddy was it coded to your sciroccos vin number and how much did it cost to activate everything?
if not (older cars) - CP can be remove permanent from radio
not a big deal now
Could you explain more? I am asking about fitting it in the Scirocco.
Thx
- I drive a: R-Line
- In: Ultra Violet
Hello,
I also put a Discover Media PQ (to replace my RNS315) a few days ago but the microphone no longer works?
Is there an adaptation to be made on the original harness or simply coding?
J'ai la camera de recul (d'origine) pour RNS315, j'ai donc commander cette adaptateur : But does anyone have a diagram to integrate the adapter correctly/cleanly... please?
VW Scirocco facelift 2015
