VCDS readings
boggy19
VCDS readings
Hi all, am I having trouble my 2.0 tdi cfgb cut out while driving and now it cranks but no start. I have no fault codes have checked all sensors and wiring and readings the Hpfp is clean and no swarf. Am I missing something in the readings thanks.
