Bluetooth 2015 Facelift Disappeared
Cmorgan773
In: Pure White
Options: N/A
Post by Cmorgan773 »
Apologies if this has been asked before but can't find the answer.
My Bluetooth has completely disappeared from my 2015 facelift Scirocco. I've tried all the previous suggestions and I've had the entire radio out but no success. Has anyone on a 2015-2017 model had this issue and how did you fix it?
Also just to add the BT cable location isn't under either my drivers seat or passenger seat, just in-case anyone was to suggest this.
Appreciate any help or suggestions!
Re: Bluetooth 2015 Facelift Disappeared
I think on your model of Scirocco, the BT is integrated into the head unit hence why there is no module under the driver's seat.
I assume you have checked the settings and haven't accidentally disabled it but you could also see if you can do a factory reset on the headunit. Other than that it might be a fault within the headunit.
