RNS510 Retrofit - Under Seat Harness Length
wayne1234
Post by wayne1234 »
Morning All,
Quick question for anyone who has retrofitted this wiring harness under the drivers seat.
Is this Harness long enough to go from the seat to the back of the radio?
Dreamer
Re: RNS510 Retrofit - Under Seat Harness Length
Post by Dreamer »
Yes it is. I unbolted my seat and moved it to the rear without unplugging it as there are cut outs in the carpet. I ran it under the centre tunnel (very tight to access but can be done). There was plenty of slack left and it was neatly done.
wayne1234
Post by wayne1234 »
Perfect. Thanks for the reply :-)
wayne1234
Post by wayne1234 »
Fitted the Retro kit from EuroZone Tuning.
All works perfectly without any coding. Even the steering Voice Command works :-)
Dreamer
Post by Dreamer »
Good result [emoji41][emoji106]
