Throttle pedal
blz-8027
In: Night Blue
Throttle pedal
Post by blz-8027 »
Anyone changed the accelerator pedal
you tube states need a special tool
is it needed ?
MackemVR6
In: Shadow Blue
Re: Throttle pedal
Post by MackemVR6 »
This is what the tool looks like https://www.ebay.co.uk/itm/192535321991" onclick="window.open(this.href);return false;
You can make your own up or just use a couple of screwdrivers. The pin on the right gets pushed to the left and the one on the left gets pushed back. There is a torx screw to be removed too. It's pretty simple. I found the hardest bit getting the connector off.
blz-8027
In: Night Blue
Re: Throttle pedal
Post by blz-8027 »
MackemVR6 wrote:This is what the tool looks like https://www.ebay.co.uk/itm/192535321991" onclick="window.open(this.href);return false;
Thanks for the reply ,ill give it a go as soon as its not raining when i have time to do it
