Face-lift Scirocco R Headlights
SteveBZ
I drive a: 1.4 TSI 122/125
In: Urano Grey
Post by SteveBZ »
HI Guys,
Does anyone know whether it is possible to fit the BI-Xenon headlights the R comes out with on a Standard Face-lift Scirocco?
Thanks in advance
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Re: Face-lift Scirocco R Headlights
Post by davidscirocco »
you mean if you can install pre facelift bi xenon headlights to the facelift scirocco that has hallogen ?
or facelift bi xenon headlights to the facelift scirocco that has hallogen?
either way it is possible but you have to make a search here on the forum to see how to do it
finetrond
Post by finetrond »
I'm quite sure they have to be coded to work, these new fangled cars have computers to check everything. If the resistance changes the cars think the lights are failed. Check in the VCDS forum. Few more posts and you should be able to PM some of the chingalera tuners who can get a rocco copmuter to work with golf 4wd.
As long as the lamps fit you be fine, even if they don't fit the can be made to work. it'll look a bit funny, but work.
Collector of warning lights.
